Backup Encryption Check
Rule Details
Parameter |
Description |
Rule Name |
cbr-backup-encrypted-check |
Identifier |
Description |
If a CBR backup is not encrypted, this backup is non-compliant. |
Tag |
cbr |
Trigger Type |
Configuration change |
Filter Type |
cbr.backup |
Rule Parameters |
None |
Application Scenarios
If the disk to be backed up is encrypted, the backup will also be encrypted. You cannot manually encrypt or decrypt backups. For how to create a disk backup, see Creating a Disk Backup.
Backup encryption can control internal personnel's access to data, reducing the risk of internal leakage.
Solution
Ensure that the EVS disk to be backed up is encrypted. For details, see Managing Encrypted EVS Disks.
Rule Logic
- If a CBR backup is encrypted, this backup is compliant.
- If a CBR backup is not encrypted, this backup is non-compliant.
