Accounts Have Been Added to Organizations
Rule Details
Parameter |
Description |
Rule Name |
account-part-of-organizations |
Identifier |
Description |
If an account has not been added to any organizations or to a specified organization, this account is non-compliant. |
Tag |
organizations |
Trigger Type |
Periodic |
Filter Type |
Account |
Rule Parameters |
domainId: administrator account ID of the organization to which your account belongs. An empty string indicates any account ID. |
Application Scenarios
The Organizations service helps you manage multiple accounts within your organization. It enables you to consolidate multiple Huawei Cloud accounts into a single organization so you can manage the accounts all in one place. You can centrally manage policies in Organizations. This helps you better meet the security and compliance requirements of your business. For details, see What Is Organizations?
Rule Logic
- If an account does not join an organization, the check result is non-compliant.
- If an account has joined an organization and the administrator account ID of the organization matches the rule parameter, the check result is compliant. If the rule parameter is an empty string, any administrator account ID is allowed.
- If an account has joined an organization and the administrator account ID of the organization does not match the rule parameter, the check result is non-compliant.
