Updated on 2025-09-09 GMT+08:00
DMS for Kafka Should Not Be Publicly Accessible
Rule Details
Table 1 Rule Details
Rule Name
dms-kafka-public-access-enabled-check
Identifier
DMS for Kafka Queues Are Not Publicly Accessible
If a DMS for Kafka queue can be accessed over a public network, this queue is non-compliant.
Tag
dms
Trigger Type
Configuration change
Filter Type
dms.kafka
Rule Parameters
None
Application Scenarios
You can enable public access to a Kafka instance to use it over a public network. In this case, you do not need this preset policy, but you need to take strict security measures, such as configuring strict security group or firewall rules and enabling public network access.
If public network access is no longer needed, disable it to prevent the Kafka queues from being exposed to the public network.
Solution
Disable public network access. For details, see Configuring Kafka Public Access.
Rule Logic
  • If a DMS for Kafka queue can be accessed over a public network, this queue is non-compliant.
  • If a DMS for Kafka queue cannot be accessed over a public network, this queue is compliant.
