Both Error Logs and Slow Query Logs Are Collected for RDS Instances
Rule Details
Parameter |
Description |
Rule Name |
rds-instance-logging-enabled |
Identifier |
Description |
If neither error logs nor slow query logs are collected for an RDS instance, this instance is non-compliant. |
Tag |
rds |
Trigger Type |
Configuration change |
Filter Type |
rds.instances |
Rule Parameters |
None |
Application Scenarios
The database audit function records all user operations on the database in real time. This function logs, analyzes, and reports user activities in the database. Based on the audit logs, you can prepare compliance reports and track incidents, improving data asset security. For details, see Enabling Database Audit for Post-Event Backtracking.
Solution
Configure audit log policies (including slow query logs, error logs, and SQL audit logs) for the RDS instance. For details, see Setting SQL Audit and Enabling SQL Audit.
Rule Logic
- If slow query logs, error logs, and SQL audit logs are enabled for an RDS instance, this instance is compliant.
- If slow query logs, error logs, and SQL audit logs are not enabled for an RDS instance, this instance is non-compliant.
