Updated on 2025-08-25 GMT+08:00
RDS Instances Support Slow Query Logs
Rule Details
Table 1 Rule details
Rule Name
rds-instance-enable-slowLog
Identifier
If slow query logging is not enabled for an RDS DB instance, this instance is non-compliant.
Tag
rds
Trigger Type
Configuration change
Filter Type
rds.instances
Rule Parameters
None
Application Scenarios
Slow query logs record statements that exceed the execution duration threshold. You can view log details and statistics to identify statements that are executing slowly and optimize the statements. You can also download slow query logs for service analysis.
Solution
Configure slow log collection. For details, see Log Configuration Management.
Rule Logic
  • If slow query logging is not enabled for an RDS DB instance, this instance is non-compliant.
  • If slow query logging is enabled for an RDS DB instance, this instance is compliant.
