Help Center/
Config/
User Guide/
Resource Compliance/
Configuring Remediation for Compliance Rules/
Deleting Remediation Configurations
Updated on 2025-09-09 GMT+08:00
You can delete the remediation configurations of a compliance rule if it is no longer needed. Deleting the remediation configurations of a compliance rule does not affect the resources that have been remediated.
- Click
in the upper left corner of the page. Under Management & Governance, select Config.
- In the navigation pane on the left, choose Resource Conformance.
- On the Rules tab, click the name of a rule that has remediation configured to go to the details page.
- Click the Remediation tab.
- In the upper right corner of the page, click Delete.
Figure 1 Deleting remediation configurations
Parent topic: Configuring Remediation for Compliance Rules
