GES Graphs Have LTS Enabled
Rule Details
Parameter |
Description |
Rule Name |
ges-graphs-lts-enable |
Identifier |
Description |
If a GES graph has LTS disabled, this graph is noncompliant. |
Tag |
ges |
Trigger Type |
Configuration change |
Filter Type |
ges.graphs |
Configure Rule Parameters |
None |
Applicable Scenario
If you need to check service logs, enable LTS.
Solution
You can enable LTS for noncompliant GES graphs. If there are no log groups and log streams available, go to LTS console to create one. For details, see Enable LTS.
Rule Logic
- If a GES graph has LTS disabled, this graph is noncompliant.
- If a GES graph has LTS enabled, this graph is compliant.
