Help Center/ Config/ User Guide/ Resource Compliance/ Built-In Policies/ Distributed Cache Service/ DCS Memcached Instances Are in a Specified VPC
Updated on 2025-01-20 GMT+08:00
Rule Details
Table 1 Rule details
Rule Name
dcs-memcached-in-vpc
Identifier
If a DCS Memcached instance is not in the specified VPC, this instance is noncompliant.
Tag
dcs
Trigger Type
Configuration change
Filter Type
dcs.memcached
Configure Rule Parameters
vpcId: The VPC ID. The value must be a string.
Applicable Scenario
A VPC is a private network on the cloud. You can create VPCs to logically isolate your DCS Memcached instances. For more details, see What Is Virtual Private Cloud?
Solution
You can redeploy noncompliant DCS Memcached instances to required VPCs. DCS Memcached has been discontinued. You are advised to use DCS for Redis instead. For details, see Huawei Cloud Distributed Cache Service Memcached Is Discontinued.
Rule Logic
  • If a DCS Memcached instance is not in the specified VPC, this instance is noncompliant.
  • If a DCS Memcached instance is in the specified VPC, this instance is compliant.
