Updated on 2025-08-25 GMT+08:00
Flavor Check
Rule Details
Table 1 Rule details
Rule Name
allowed-ecs-flavors
Identifier
Flavor Check
If an ECS's flavor is not one of the specified flavors, this ECS is non-compliant.
Tag
ecs
Trigger Type
Configuration change
Filter Type
ecs.cloudservers
Rule Parameters
listOfAllowedFlavors: the list of allowed ECS flavors
Application Scenarios
When you are purchasing an ECS, you need to specify the CPU and memory configurations based on service requirements. If the specifications are too high, expenses will be wasted. If the specifications are too low, services will be interrupted.
There are a wide range of ECS types available to meet your compute and storage requirements. For details, see Supported ECS Types.
Solution
Scale up vCPUs and memory of your ECSs to meet service requirements. Certain ECSs also support changing ECS types during specifications modification. For details, see Modifying Specifications of Individual ECSs.
Rule Logic
  • If an ECS's flavor is one of the specified flavors, this ECS is compliant.
  • If an ECS's flavor is not one of the specified flavors, this ECS is non-compliant.
