Help Center/ Config/ User Guide/ Resource Compliance/ Built-In Policies/ API Gateway/ Dedicated API Gateways Have Logging Enabled
Updated on 2025-08-25 GMT+08:00
Rule Details
Table 1 Rule details
Rule Name
apig-instances-execution-logging-enabled
Identifier
If logging is not enabled for a dedicated API gateway, this instance is non-compliant.
Tag
apig
Trigger Type
Configuration change
Filter Type
apig.instances
Rule Parameters
None
Application Scenarios
APIG provides visualized analysis and statistics of APIs, allowing you to view API call logs. You will have the following benefits using APIG:
  • Abnormal access detection: Audit logs allow you to identify abnormal access events, such as frequent failed requests and requests from abnormal IP addresses, and detect potential attacks.
  • Easy troubleshooting: The cause of API call failures, such as parameter errors and service unavailability, can be quickly located with the logs.
  • User behavior analysis: You can understand user behavior and optimize your product by analyzing API call patterns.
  • Resource usage monitoring: You can have a clear vew of the API call frequency and resource consumption and take actions to prevent resource waste.
Solution
Enable logging, and configure log management and log dump. For details, see Viewing API Call Logs.
Rule Logic
  • If logging is not enabled for a dedicated API gateway, this instance is non-compliant.
  • If logging is enabled for a dedicated API gateway, this instance is compliant.
