Resource Tag Check
Rule Details
Parameter |
Description |
Rule Name |
required-tag-check |
Identifier |
Description |
If a resource does not have the specified tag attached, this resource is non-compliant. |
Tag |
tag |
Trigger Type |
Configuration change |
Filter Type |
Rule Parameters |
Application Scenarios
After a company migrates to the cloud, as their cloud resources keep growing, they usually need to manage hundreds of thousands or millions of resources within one account. Manually classifying these resources is difficult and inefficient. To meet this challenge head on, you will need a cloud service to manage resources automatically.
Tag Management Service (TMS) enables you to classify and group resources with tags. You can tag resources by their attributes, such as by department, region, or project. For details, see Principles for Naming Tags.
Solution
Add one or more tags to a single cloud resource or to multiple cloud resources at a time on the TMS console. For details, see Adding Resource Tags.
Rule Logic
- If specifiedTagValue is empty and a resource has a specifiedTagKey, the resource has the specified tag attached.
- If specifiedTagValue is not empty and a resource has a specified tag key and a tag value specified in TagValues, the resource has the specified tag attached.
- If a resource has a specified tag attached, the resource is compliant.
- If a resource does not have a specified tag attached, the resource is non-compliant.
