Updated on 2026-04-16 GMT+08:00
Querying All Resources
On the Resource List page, you can view resources in the current account.
- Resource synchronization to Config is asynchronous; therefore, resource changes may not reflect in the list immediately. Once the resource recorder is enabled, Config typically updates resource states within 24 hours.
- To populate the resource list, ensure the resource recorder is active. If resources do not appear, verify that the recorder is enabled, the resource type is within the configured monitoring scope, and the specific service is supported by Config. For details about how to configure the resource recorder, see Configuring the Resource Recorder.
- If you have not enabled the resource recorder and want to view the resources you own, go to the My Resources page.
- Log in to the Config console.
- On the Resource List page, the resources you own within the monitoring scope of the resource recorder are displayed by default. Figure 1 Resource List
- Disable Only display cloud services and regions that contain resources and then click More to view all services that are supported by Config. Figure 2 Viewing all services supported by Config
- To view all supported services and regions, click Supported Services and Regions.
Parent topic: Viewing Resources
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
