Connecting to an RDS for PostgreSQL Instance Using Python
You should be familiar with:
- Computer basics.
- Python programming language.
- How to use psycopg2.
Installation Dependency
Install psycopg2 to connect to PostgreSQL databases.
pip install psycopg2
Parameters
| Parameter | Description |
| dbname | The name of the database to be connected. The default database name is postgres. |
| user | The username used for connecting to the database. |
| password | The password of the username. |
| host |
| port | The port number shown on the Overview page of the DB instance. The default port number is 5432. |
| sslmode | The SSL connection mode.
| sslrootcert | The path of the server certificate. |
Connecting to the Instance with an SSL Certificate
The following code is an example of how to use the psycopg2.connect function to connect to an RDS for PostgreSQL instance based on SSL certificate authentication and how to use the cursor.execute method to run INSERT and UPDATE statements on the instance.
    An error "permission deny for schema public" may be reported when you create tables on certain instance versions. To resolve this problem, use the grant create on SCHEMA public to root; command.
import psycopg2
db_params ={'database':'postgres','user':'root','password':'****','host':'xxx.xxx.xxx.xxx','port':'5432','sslmode':'verify-ca','sslrootcert':'/path/to/CA/ca.pem',}
conn=psycopg2.connect(**db_params)
print("Connection established")
cursor = conn.cursor()
# Drop previous table of same name if one exists
cursor.execute("DROP TABLE IF EXISTS inventory;")
print("Finished dropping table (if existed)")
# Create a table
cursor.execute("grant create on SCHEMA public to root;")
cursor.execute("CREATE TABLE inventory (id serial PRIMARY KEY, name VARCHAR(50), quantity INTEGER);")
print("Finished creating table")
# Insert some data into the table
cursor.execute("INSERT INTO inventory (name, quantity) VALUES (%s, %s);",("banana",150))
cursor.execute("INSERT INTO inventory (name, quantity) VALUES (%s, %s);",("orange",154))
cursor.execute("INSERT INTO inventory (name, quantity) VALUES (%s, %s);",("apple",100))
print("Inserted 3 rows of data")
cursor.execute("SELECT * FROM inventory;")
result = cursor.fetchall()
for row in result:
    print(row)
# Clean up
conn.commit()
cursor.close()
conn.close()
   The command output is as follows:
Connection established Finished dropping table(if existed) Finished creating table Inserted 3 rows of data (1,'banana',150) (2,'orange',154) (3,'apple',100)
Connecting to the Instance Without an SSL Certificate
The following code is an example of how to connect to an RDS for PostgreSQL instance without using an SSL certificate.
import psycopg2
db_params ={'database':'postgres','user':'root','password':'****','host':'xxx.xxx.xxx.xxx','port':'5432','sslmode':'disable'}
# Create a table
for row in result:
    print(row)
# Clean up
conn.commit()
cursor.close()
conn.close()
