Manually Switching Between Primary and Standby DB Instances
If you choose to create a primary/standby DB instance, RDS will create a primary DB instance and a synchronous standby DB instance in the same region. You can access the primary DB instance only. The standby instance serves as a backup. You can manually promote the standby DB instance to the new primary instance for failover support.
During a primary/standby switchover, the API for querying databases cannot be called.
You can switch the primary and standby instances only when all of the following conditions are met:
- The DB instance is running properly.
- The primary/standby replication is normal.
- The replication delay is less than 5 minutes, and the data on the primary and standby instances is consistent.
- Click
in the upper left corner and select a region. - Click
in the upper left corner of the page and choose Databases > Relational Database Service. - On the Instances page, click the target primary/standby instance name to go to the Summary page.
- Under DB Instance Type, click Switch.
A primary/standby switchover may cause a brief interruption of several seconds or minutes (depending on the replication delay). If transaction logs are generated at a speed higher than 30 MB/s, services will probably be interrupted for several minutes. To prevent traffic congestion, perform a switchover during off-peak hours.
- If you have enabled operation protection, click Send Code in the displayed Identity Verification dialog box and enter the obtained verification code. Then, click OK.
Two-factor authentication improves the security of your account and cloud product. For details about how to enable operation protection, see the Identity and Access Management User Guide.
- After the switchover is successful, check the status of the DB instance on the Instances page.
- During the switchover, the DB instance status is Switchover in progress.
- In the upper right corner of the DB instance list, click
to refresh the list. After the switchover is successful, the DB instance status will become Available.
