Updated on 2026-10-19 GMT+08:00
Creating a RabbitMQ Virtual Host
Each virtual host serves as an independent RabbitMQ server. Virtual hosts provide logical separation of exchanges, queues, and bindings. Different applications run on different virtual hosts without interfering with each other. An instance can have multiple virtual hosts, and a virtual host can have multiple exchanges and queues. To connect a producer or consumer to a RabbitMQ instance, you must specify a virtual host. For details, see Virtual Hosts on the official RabbitMQ website.
Figure 1 Virtual host architecture
Table 1 Constraints
Version
3.x.x
  • After an instance is created, a virtual host named / is automatically created.
  • When a virtual host name starts with a special character, such as a period (.), the monitoring data may not be displayed.
  • When a virtual host name contains special characters such as a percent (%), vertical bar (|), slash (/), period (.), or hyphen (-), these special characters will be displayed as underscores (_) on the monitoring page. For example, virtual host Vhost.1%1|2_3/ is displayed as Vhost_1_1_2_3_ on the monitoring page. If the virtual host names displayed on the monitoring page are the same after the special characters in them are replaced with underscores (_), the monitoring data of the virtual hosts with the same name will overlap.
  • On Cloud Eye, a special character (.) is counted as five characters. If the name of a queue or virtual host contains periods (.) and the total length exceeds 256 characters, monitoring data may not be displayed.
  • Virtual hosts can be created on the console and management UI.
AMQP-0-9-1
  • After an instance is created, a virtual host named default is automatically created.
  • Virtual hosts can be created only on the console.
A virtual host can be created on the console or management UI.
  1. Log in to the RabbitMQ console.
  2. Click in the upper left corner to select the region where your instance is located.
  3. Click in the upper left corner and choose Application > Distributed Message Service for RabbitMQ to open the RabbitMQ instance list.
  4. Click an instance name to go to the instance details page.
  5. In the navigation pane, choose Instance > Virtual Hosts.
  6. Click Create Virtual Host.
  7. Enter a virtual host name and click OK.
    Table 2 Virtual host naming rules
    Version
    Naming Rule
    3.x.x
    Use 2 to 128 characters, including letters, digits, and special characters .%|-_/. The name cannot be two periods (..).
    AMQP-0-9-1
    Use 2 to 32 characters, including letters, digits, and special characters .%|-_/. (Each special character is counted as three characters.) The name cannot be two periods (..).
    Once a virtual host is created, its name is fixed and it is displayed in the virtual host list.
    Tracing indicates whether message tracing is enabled. This parameter is available only in RabbitMQ 3.x.x. If it is enabled, you can trace the message forwarding path.
    Figure 2 Virtual host list (RabbitMQ 3.x.x)
    Figure 3 Virtual hosts (RabbitMQ AMQP-0-9-1)
  1. Log in to the RabbitMQ management UI.
  2. On the top navigation bar, choose Admin.
  3. In the navigation tree on the right, choose Virtual Hosts.
    Figure 4 Virtual hosts
  4. In the Add a new virtual host area, enter the virtual host name and click Add virtual host.
    Figure 5 Creating a virtual host (management UI)
    After the creation is successful, the new virtual host is displayed in the All virtual hosts area.
    Figure 6 Virtual host list (management UI)
Helpful Links
To create a virtual host by calling an API, see Creating a Virtual Host.
