Help Center/
Distributed Message Service for RabbitMQ/
User Guide/
Managing Instances/
Exporting the RabbitMQ Instance List
Updated on 2025-07-14 GMT+08:00
You can export a list of instances on the RabbitMQ console.
- Log in to the RabbitMQ console.
- In the upper left corner, click
and select a region. - Export the instance list in either of the following ways:
- Select the desired instances and choose Export > Export selected data to an XLSX file to export specified instances.
- Choose Export > Export all data to an XLSX file to export all instances.
