Creating a Role
You have logged in to the Huawei Qiankun console and have one of the permissions of the following roles:
- Preset role: MSP administrator permission
- Custom role: role management permission of the user and tenant service
Context
The operation permissions of an MSP for using Huawei Qiankun are determined by the roles assigned to the MSP.
The console provides preset roles for each service. MSPs can also configure custom roles.
- Click your account in the upper right corner, and choose . The Role Management page is displayed.
- Click Create, enter the name of a custom role, specify operation permissions, and click OK.
Upon creation, a role can be assigned to MSP users in lower-level workgroups.
Figure 1 Creating a role
Follow-up Procedure
Custom roles support the view, modify, delete, and search operations on permissions, whereas preset roles support only the view and search operations on permissions.
- View: Select a role and click
in the Operation column to view its permissions. In the View Role Permissions dialog box, you can further filter the query or edit permissions of the role.
Figure 2 Viewing permissions of a role
- Search: Enter a role name in the search box, and click
on the left or press Enter to search for the role. - Modify: Select a role, and click
in the Operation column to modify the operation permissions of the role. - Delete: Select a role, and click
in the Operation column or Delete above the user list to delete the role. If a role has been assigned to a lower-level workgroup, operation permissions of this workgroup will be affected after the role is detected. Therefore, exercise caution when deleting a role.
