Using a Project Template
In CodeArts, projects are the basis for using services. Operations such as requirement planning, code management, build, and deployment must be performed in CodeArts projects. CodeArts provides multiple preset project templates for different requirement management processes.
Before creating a CodeArts project, you must have permission to create a project. If the Create Project button is not displayed on the homepage, you do not have permission to create projects. In this case, contact the administrator to obtain the permission. For details about how to grant the project creator permission to users, see Configuring a CodeArts Project Creator.
Creating a CodeArts Project Using a Project Template
CodeArts provides multiple out-of-the-box project templates, including Scrum, IPD. You can select a project template based on your service scenario.
- Click Create Project on the service homepage.
- On the Select Template page, select a project template as required. For details about the characteristics and application scenarios of each project template, see Table 1.
Table 1 Project template features and application scenarios Project Template
Template Feature
Application Scenario
Scrum
An incremental, iterative software development method. Sprint planning, daily Scrum, sprint review, and sprint retrospectives are key to efficient project management.
Iterative, incremental software development.
IPD-System Device
Software and hardware adaptation involved, fixed product requirements, industry standards available, long development period (6–9 months), high requirements on product quality and stability, many decisions to make, and mainly waterfall development.
Complex products with embedded software that evolves with hardware. Examples: communications devices, automobiles, home appliances, and consumer electronics.
IPD-Standalone Software
Independent software deployment and sales, frequent requirement changes, quick planning, agile development, agile release, and short delivery period (2–3 months or faster).
IT application and platform software with standardized hardware or independent of dedicated hardware. Examples: ERP software, CRM, databases, and network management software.
- Select a project template and click Select. On the Create Project page, set related parameters.
Table 2 Creating a project Parameter
Work item template
The work item template contains all the configuration items for a Scrum project, except for the work item fields, status transition, automatic transition, and handlers of work items in specific statuses. Select a template as needed. After the selection, the work item configuration data of the project can be quickly reused.
In addition to the default Scrum template, you can also customize a template as follows: Open a project, choose . On the displayed page, click Fields and Templates to access the work item template page. Click Edit Template and click Save as Template after configuration. Work Item Template is available only for Scrum projects.
Name
Set this parameter as required.
- The name of projects under the same tenant must be unique.
- The value can contain 1 to 128 characters. Only letters, digits, and symbols are supported.
Code
This parameter is set for third-party services. A project code is set to facilitate service management.
Enter a maximum of 200 characters. Only digits, letters, hyphens (-), and underscores (_) are supported.
Enter a brief description of the project.
The value can contain a maximum of 1,024 characters.
- Click OK. The project is created successfully and the project page is displayed.
Related Operations
For a new project, members with the edit permission can choose and perform the following operations.
Operation |
Procedure |
Remarks |
Edit basic project information |
Transfer the project creator |
If the project creator is deleted from IAM, the project ownership is automatically transferred to the project manager. If the project creator is also the project manager, the project ownership is transferred to the administrator account. |
Archive a project |
Delete a project |
Manage the project service menu |
Manage project members/permissions |
