Help Center/ CodeArts Req/ User Guide/ Custom Requirement Models/ Review Check Items/ Enabling Review Check Items in Review Settings
Updated on 2026-10-26 GMT+08:00
- A project already exists.
- A review checklist template has been configured.
- You have the permission to set reviews on the work configuration page.
- Go to the project and choose .
- Configure review check items.
Configure whether to enable review check items for the review and select the review checklist template to be used.
- Configure whether to enable review check items.
- If the switch is toggled on (
), review check items are enabled. If review check items need to be used in reviews, toggle on the switch. - If the switch is toggled off (
), review check items are disabled.
- Configure the associate review checklist template.
Click
in the row of the review. In the displayed dialog box, select Related Review Check Item Template from the drop-down list and click OK.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
