Creating System Features
Major capabilities of offering requirements or services to support a problem (PB) can be managed in system features. When creating a system feature, you can set its background, value, details, and priority.
An IPD-standalone software project is available, in which you have permission to create and duplicate feature sets.
- Access the CodeArts Req homepage.
- On the project homepage, choose Feature Tree.
- Click SF. On the SF page, set related parameters.
Table 1 System feature parameters Parameter
Tag
When creating or editing a work item, you can add a custom tag.
Tag names can be marked in different colors.
Title
Name of a system feature.
Enter the background, value, and details of the feature based on project requirements.
Use text, images, or links.
A maximum of 100 attachments can be added to a system feature, and their total size cannot exceed 500 MB.
Responsible Project
Project that the system feature belongs to. The value cannot be changed.
Owner
Owner of the system feature. Only one owner can be selected. The default owner is the creator.
Feature Set
The feature set to which the system feature belongs is a home structure of the feature tree.
Priority
Priority of the system feature, including Low, Medium, and High. The default value is Medium.
Planned Start
Planned start time.
Planned Completion
Planned completion time. It cannot be earlier than the planned start time.
Planned Workload
Planned workloads.
High Value
Whether the system feature is a key feature. The value can be Yes or No.
Used For
Scenario with a maximum of 512 characters.
Domain
Domain to which the system feature belongs.
The options include software and hardware, hardware, performance, operations, and user experience. Select one based on the system feature.
Copy To
Person to whom the system feature is copied.
- Click OK. The feature tree page is displayed. A message indicating system feature created is displayed in the upper right corner.
The new system feature is displayed in the feature tree, and the system feature state is Initial.
Figure 1 Feature tree
After a feature is created, the people selected for Owner and Copy To will receive email and system message notifications. If not, set notifications or modify notification settings. For details, see Configuring Notifications.
Related Operations
You can perform the following operations on a new system feature.
| Operation | Description |
| Modify title | Click |
| Modify field | Click the target field value in the row of a system feature to modify the value. |
| Break down work item | Click
| Duplicate system feature | Choose |
| View association map | Choose |
| Copy system feature link | In the system feature list, you can copy the title, ID, current owner, status, and link information of a system feature to the clipboard. SFs: Click Copy Link under IRs/USs: Click |
| Delete system feature | Choose
| Perform batch operations | Select multiple system features and perform the following operations:
