Deleting Bugs
You can delete invalid and closed bugs to release the project space.
- A project has been created.
- A bug has been created.
- In the bug list, select the bugs to be deleted.
- To delete a single bug, click in the row where the task to be deleted is located and choose Delete. The Warning dialog box is displayed.
- To delete one or more bugs, select the bugs to be deleted and click Delete. The Information dialog box is displayed.
- Click Delete. A message is displayed, indicating that the deletion is successful.
More Operations
Deleted bugs can be restored from Recycle Bin.
- On the Bugs homepage, click Recycle Bin in the upper right corner.
- Select the bugs to be restored.
Multiple bugs can be selected.
- Click Recovery in the lower right corner of the window. A confirmation dialog box is displayed.
To restore a single bug, click in the row where the bug is located.
- Click OK to restore the bug.
The restored bug is displayed in the bug list, staying in the status before deletion.
