Managing Tasks
After creating tasks (see Creating Tasks), you can query, import, export, and batch edit them in the project. You can add tags and associate work items on their details pages.
Operation |
Procedure |
Search for task |
Import work items |
Use the provided template to import tasks in batches.
Export work items |
Export requirements in batches to an Excel file.
Configure fields to display |
Click next to the Operation field.
Clone tasks across projects |
Transition statuses in batches |
Perform batch operations |
You can select multiple tasks to perform operations in batches: edit, suspend/unsuspend, export, delete, cross-project clone, and transition. |
Group tasks |
You can group work items by any supported field type. Constraints
Operation |
Procedure |
Remarks |
Edit work item |
On the task details page, click the value box of the field to be modified, and enter a target value in the text box or select one from the drop-down list. The modification is saved automatically. |
You must have permission to edit tasks. |
Change work item status |
Go to the work item details page, click the Status field, and transition the work item to the target status. For details about status transition, see Table 1. |
You must have permission to set statuses for tasks. |
Upload attachment |
Attachments can be pictures, workbooks, manuscripts, and text files. A maximum of 100 attachments can be added to each work item, and their total size cannot exceed 500 MB.
You must have permission to edit or upload attachments for tasks. |
Add and check related item |
A work item can be associated with other types of work items in a project.
You must have permission to associate/dissociate parent task, create subtasks, associate/dissociate work items, associate/dissociate files, and associate/dissociate wikis for tasks. |
Add workload |
You must have permission to add person-hours for tasks. Workloads can be edited and deleted by the creator. By default, the project administrator can edit and delete all workloads. |
View operation history |
History displays all operation logs of users, including creation, status transition, review initiation, work item association, and workload addition.
You must have permission to view tasks. |
Tag work item |
Add comment |
