Updated on 2026-10-26 GMT+08:00
Managing RRs
After creating RRs (see Creating RRs), you can query, import, export, and batch edit them in the project. You can add tags and associate work items on their details pages.
You have created an RR in an IPD-standalone software project and have permissions on the RR in the project.
Go to the project homepage, choose Work > Req > Raw Requirements, and perform the following operations.
Figure 1 RR list
Table 1 Management operations in the RR list
Operation
Query RR
You must have the View list permission for RRs.
  • By adding filters
    1. Click the search box in the RR list and select one or more filters to search for RRs.
    2. To clear all filters and display all data, click on the right of the search bar.
    3. Query results can be displayed in tree, list, or Gantt chart view.
  • By using a saved view
    1. Click the search box in the RR list and select one or more filters.
    2. Click on the rightmost of the search bar, and enter a view name.
    3. Click OK. The created view is displayed next to RR.
    4. Select the name of the created view to query the RRs that meet the search criteria.
      Views can be shared with others, modified, and deleted.
Import work items
Use the provided template to import requirements in batches.
You must have the Import permission for RRs.
  1. In the RR list, click on the right of the search bar and select Import.
  2. In the displayed dialog box, click Download Template.
    The template file should be named in the following format: Project name + "-" + Module name (for example, RR) + Template. You can edit the name of the downloaded template.
  3. Fill in the fields on the RR Import sheet.
    For details about how to set parameters, see the Notes and header instructions in the template file.
  4. Drag and drop the desired file to the import area or click the import area and select the file.
  5. Click Next. The verification progress dialog box is displayed.
    After the verification progress reaches 100%, close the dialog box and view the verification result. If the mandatory fields fail the verification, the import is not allowed, while the verification result of optional fields does not affect the import.
    • If the verification is successful, click Confirm Import.
    • If the verification fails, modify the file based on the verification result. Click Last step to import the modified file.
  6. After the verification is successful, click Confirm Import. The import progress dialog box is displayed. You can click Check progress in the dialog box to go to the Import/Export Records page to view the import records.
  7. After the import is successful, you can view the imported information in the RR list.
    • If the import fails, a message is displayed on the page. Click View Failure Details in the message to view the failure details. You can modify the requirement information based on the details and import the template file again.
Export work items
Export requirements in batches to an Excel file.
You must have the Export permission for RRs.
  1. Export some or all RRs.
    • Export all: On the Raw Requirements page, click on the right of the search bar and choose Export. The Select Fields to Export dialog box is displayed.
    • Export some: In the RR list, select one or more RRs to be exported and click Export Selected at the bottom of the page. The Select Fields to Export dialog box is displayed.
  2. Select the fields to be exported and determine whether to export child work items.
  3. Click Export. A dialog box is displayed, indicating the export progress.
    • After the RRs are exported, click Download. The RR file will be downloaded to the local PC. The file format is .xlsx.
Configure fields to display
Click next to the Operation field.
  • On the left of the pop-up box, select the fields to be displayed.
  • On the right of the pop-up box, drag the fields in the Selected area to adjust the display sequence.
  • On the right of the pop-up box, select a field spacing style under Appearance. The options include Compact, Standard, and Loose.
Clone RR across projects
You must have the Create/Submit/Copy permission for the target project.
  • Only RRs of the current project can be cloned to other projects. The workload, associated work item, tag, and release sprint fields will be cleared.
  • RRs can be cloned only to projects of the same type.
  • You can clone up to 50 RRs at a time.
  • Draft RRs and RRs of other projects cannot be cloned.
  1. Select the RRs to clone in the RR list and click Cross-Project Copy in the lower part of the page. The Cross-Project Copy window is displayed.
  2. Select a target project from the drop-down list. You can select only a project to which you have joined and must have permission to create and clone tasks for the target project.
  3. Click Next. The window for setting mandatory fields is displayed. Select the target owner from the drop-down list (the current operator is selected by default). Mandatory fields are those on the RR creation page of the target project.
  4. Click OK. The RRs are cloned to the target project.
  5. Go to the target project to view the cloned RRs.
Transition statuses in batches
You must have the Set statuses permission for RRs.
  • The types of the selected work items must be the same.
  • Only RRs of this project support batch status transition.
  • The selected RRs must be in the same status.
  • The mandatory fields of the selected RRs are filled.
  1. Select the target RRs in the RR list and click Batch Transfer in the lower part of the page. The Batch Transfer window is displayed.
  2. Select the target status from the drop-down list.
  3. Click Next.
  4. Set mandatory fields. The mandatory fields are set on the In-transition GUI Config tab of the project's RR status flow configuration page.
  5. Click OK.
Migrate work items
You must have the Migrate permission for RRs.
  • Only RRs of this project can be migrated.
  • After the migration to a new responsible project, the system automatically removes the tag and disassociates the work item from the original project.
  • During a batch migration, you need to provide values for all mandatory fields in the target project. The system will apply your field settings to single-choice and multi-choice user fields, as well as the fields that are empty before the migration. It will not overwrite the fields that already contain data.
  1. Select the work items to be migrated in the RR list and click Migrate in the lower part of the page. The Migrate window is displayed.
  3. Select a priority from the drop-down list.
  4. Select one or more owners from the drop-down list.
  5. Click OK. The migration is successful.
    Go to the target project to view the migrated work items.
Suspend work items
You must have the Suspend/Cancel suspend permission for RRs.
  • Only RRs of this project can be suspended.
  • The status node of a work item can be suspended. That is, the Suspend/Cancel switch has been turned on in the status node settings of the status flow.
  1. Select the work items to be suspended in the RR list and click Suspend in the lower part of the page. The Suspend window is displayed.
  2. Specify a reason.
  3. Click OK. The suspension is successful.
    On the RR list page, the work item is displayed as suspended.
Unsuspend work items
  • Only RRs of this project can be unsuspended.
  • All selected work items are in the suspended state.
  1. In the RR list, select the work items to be unsuspended.
  2. Click Cancel Suspension in the lower part of the page.
    After the suspension is canceled, a message is displayed in the upper right corner of the page.
Perform batch operations
You can select multiple RRs to perform operations in batches: edit, migrate, suspend/unsuspend, export, delete, cross-project clone, and transition.
Group RRs
You can group work items by any supported field type.
  • A maximum of 1,000 work items can be displayed during grouping.
  • The supported field types include single-choice list, multi-choice list, single-choice user, multi-choice user, hierarchy, and date.
  • For RRs of other projects and projects in a program (after sub-project aggregation is enabled), grouping by release, sprint, module, feature set, or tag is unavailable.
  1. On the Raw Requirements page, click Group.
  2. On the displayed page, select the fields used to group work items.
    • You can sort work items in ascending or descending order.
    • You can enter a keyword to search for fields.
    • When work items are grouped by multi-select list or multi-select user, the same work item may appear in multiple groups.
    • You can click No grouping to ungroup work items.
Version snapshots
Snapshots include plan management snapshots, feature tree snapshots, and work item snapshots. A version snapshot is a work item snapshot. Its name is automatically generated by the system.
A work item can have a maximum of 1,000 snapshots.
  1. In the RR list, select the work items for which you want to create a snapshot.
  2. Click in the lower part of the page to take a snapshot of the selected work items. A message is displayed in the upper right corner of the page, indicating that the operation is successful. The snapshot is a work item snapshot. Its name is automatically generated by the system.
    The format of the work item snapshot name is: Work item type + "v" + Year + "." + Month + "." + Day + "." + Number of versions generated on the current day.
    For example, if an RR is snapshotted for the first time on March 25, 2026, its snapshot name generated by the system is RR v26.03.25.1.
    You can also go to the work item details page, click in the upper right corner, and select Version Snapshot to create a snapshot for the work item.
  3. (Optional) Click the work item name to go to its details page, click , and select Version History to view the generated snapshots.
On the details page of an RR, you can modify the description, priority, and owner, add tags and attachments, associate work items, check review records, add workloads, and view the operation history.
Figure 2 RR details page
Table 2 Management operations on the details page
Operation
Remarks
Edit work item
On the RR details page, click the value box of the field to be modified, and enter a target value in the text box or select one from the drop-down list. The modification is saved immediately.
You must have permission to edit RRs.
Change work item status
Go to the work item details page and click the transition button in the upper right corner to transition the work item to the target status. For details about status transition, see Table 1.
You must have permission to set statuses for RRs.
Upload attachment
Attachments can be pictures, workbooks, manuscripts, and text files. A maximum of 100 attachments can be added to each work item, and their total size cannot exceed 500 MB.
  1. Go to the work item details page, and click the Attachment tab.
  2. Click the box to select a local file or drag the file here to upload it as an attachment for the work item.
    Local files can be directly dragged to the text box. When the upload progress reaches 100%, the system displays a message indicating that the attachment is uploaded successfully.
    Move the cursor to the file that is successfully uploaded. The operations that can be performed are displayed.
    • Click to download the file.
    • Click to delete the uploaded file.
You must have permission to edit or upload attachments for RRs.
Add and check related item
A work item can be associated with other types of work items in a project.
  1. Go to the work item details page and click the Related Items tab.
  2. Complete association.
    • Related Upstream Requirements: requirements coordinated from upstream projects.
      The upstream requirement information is displayed in the current project only when this project is selected as the responsible project for the created Related Downstream Requirements in the RR of another project.
      Assume that the name of the current project is "IPD Project" and that of another project is "IPD Project 2". The method of synchronizing upstream requirement information is as follows:
      1. Create a project named IPD Project 2.
      2. Create an RR named RR-IPD2 in IPD Project 2.
      3. After the RR is created, enter its details page.
      4. Choose Related Items > Related Downstream Requirements and click Deliver.
      5. Set Responsible Project to IPD-Project and the raw requirement name to RR-Collaboration.
      6. After the assignment, click the requirement title "RR-Synergy" to access "IPD Project" where this requirement is located. On the RR-Synergy details page, choose Related Items > Related Upstream Requirements to view the corresponding requirement information.
      In the RR list, Collaboration Status of the RR-Synergy requirement is Received in orange, and Status is Analyzing.
      Figure 3 RR list
      Different colors of Received indicate different meanings.
      : Before a requirement is accepted, the color of Received is orange.
      : After a requirement is accepted, the color of Received turns green.
      : After a requirement is rejected, the color of Received turns red.
    • Related Downstream Requirements: requirements assigned to downstream projects.
      A maximum of 10 requirements can be assigned at a time. One requirement is displayed by default and cannot be deleted.
      1. Click Deliver.
      2. Configure related information. The current project cannot be selected for Responsible Project. If only the current project exists in the system and no value is available for this parameter, requirement assignment cannot be performed.
      3. After configuring the requirement assignment information, click OK.
      Click the requirement title "RR-test" to access "IPD Project 2" where this requirement is located.
      In the RR list, Collaboration Status of the requirement is Assign in orange.
      Different colors of Assign indicate different meanings.
      : If the current requirement has unprocessed downstream collaboration requirements, the color of Assign is orange.
      : After all downstream collaboration requirements under the current requirement are accepted, the color of Assign turns green.
      : If the current requirement has returned downstream collaboration requirements, the color of Assign turns red.
    • Child Work Items Related to RR: child work items broken down from the current work item.
      The operations vary according to the state. Perform operations based on the functions displayed on the page and the actual project situation.
      Click Break Down to add child work items.
      Each requirement can be broken down into a maximum of 10 child requirements at a time. One child requirement is displayed by default and cannot be deleted. Click to expand and configure more information.
      After the child work items are created, you can check and edit them on the R&D Requirements tab.
    • Associate Work Item: Associate work items of any type in the project.
      Work items of the RR, SF, IR, US, task, and bug types can be associated.
    • External Link: external links associated with the current work item.
      • Create a link: Click Add Link. In the displayed dialog box, set Link Name and Link. The value of Link must start with https:// and cannot contain invalid characters, such as spaces and Chinese characters. Click OK.
        After a link is created, you can click External Link to view, edit, copy, or delete the link.
      • Copy a link: Click on the right of the link to be copied.
      • Edit a link: Click on the right of the row where the link to edit is located. In the displayed dialog box, you can change the link name and link.
      • Delete a link: Click on the right of the link to be deleted. In the displayed dialog box, click Delete.
You must have permission to deliver assignment, break down/associate/dissociate child requirements, create/associate/dissociate work items, associate/dissociate files, and associate/dissociate wikis for RRs.
Check review record
You can check the review records related to requirements only in the following situations:
  • When you modify the controlled content of an RR, a change process is automatically triggered. Only then will you be able to view the review record in Review of the corresponding requirement details page.
    When you click an RR in the Confirm, Planning, or Implementing state and modify controlled fields with on the details page, a dialog box is displayed, indicating that the change approval process is required.
  • You can view the review records in Review of the corresponding requirement details page only when the requirement has a general review record.
You must have the View permission for RRs.
Add workload
  1. Go to the details page of a work item and click Workload.
  2. Click Add Workload. The Add Workload dialog box is displayed.
  3. Enter the workload information.
    • The end date cannot be earlier than the start date.
    • Decide whether to select Weekends included. If not, weekend workload records will not be generated.
    • You can select Total or Daily for Workload.
    • Work Type options include backend development, frontend development, UI design, replacement leave, debugging, and general. You can also customize the value by referring to Creating Work Types.
  4. Click OK.
    The system automatically generates corresponding records based on the entered dates and days.
    The workload can be edited and deleted.
You must have permission to add person-hours for RRs.
Workloads can be edited and deleted by the creator. By default, the project administrator can edit and delete all workloads.
View operation history
History displays all operation logs of users, including creation, status transition, review initiation, work item association, and workload addition.
  1. Go to the work item details page.
  2. Click the History tab.
    • Click or to check historical records in the ascending or descending order of operation time.
    • You can set search criteria to query historical records that meet the search criteria.
Tag work item
  1. Go to the work item details page. Click next to Tag at the top of the page, and select Create Tag.
    The added tag is displayed in the Tag area.
  2. In the Create Tag dialog box, set Tag Name and select Tag Color.
  3. Click OK.
    The new tag is displayed next to the requirement ID in the RR list.
  4. (Optional) Hide a tag.
    • Click next to Tag. In the displayed dialog box, deselect √ to hide the tag.
    • Move the cursor to the tag name and click to hide the tag.
      Figure 4 Hiding a tag - 02
      To add or remove tags for multiple RRs, you can select the desired RRs in the RR list, click Batch Edit in the lower part of the page, and select Tag.
Add comment
  2. On the Details tab page, click the Comments text box.
    Figure 5 Adding a comment
  3. Enter a comment.
    You can upload images, enter links, associate work items, and use @ to notify project members in comments.
  4. Click Submit.
    Submitted comments can be replied, edited, pinned to the top, and deleted.
History versions
For work items with snapshots, you can view their historical versions and compare the differences between them.
  1. Go to the work item details page, click in the upper right corner, and select Version History.
  2. In the Version History dialog box, select two versions and click Compare Versions. On the Work Item Version Comparison page, view the differences between the original version and the compared version. You can click in the upper right corner and enable Hide Identical Items to view only the differences between the two versions.
  3. On the Work Item Version Comparison page, click to return to the Version History page. Hover over a snapshot version. is displayed. Click to delete the snapshot.
    If a work item has a third-party snapshot or its child work items have third-party snapshots and the child work items cannot be separated from the current work item, the snapshot cannot be deleted.
You must have permission to check RRs.
To delete a snapshot, you must have permission to delete RRs.
