Updated on 2025-09-23 GMT+08:00
Managing Tasks
After creating a task (see Creating Tasks), you can perform the operations described in this section on it.
On the Task List Page
On the project homepage, choose Work > Req > Tasks, and perform the following operations.
Figure 1 Task list
Table 1 Operations in the task list
Operation
Search for task
  • By adding filters
    1. Click the search box in the task list and select one or more filters to search for tasks.
    2. To clear all filters and display all data, click on the right of the search bar.
  • By using a saved view
    1. Click the search box in the task list and select one or more filters.
    2. Click on the rightmost of the search bar, and enter a view name.
    3. Click OK. The created view is displayed next to the Task button.
    4. Select the created view to query the tasks that meet the search criteria.
      Views can be shared with others, modified, and deleted.
Import work items
Use the provided template to import tasks in batches.
  1. In the task list, click on the right of the search bar and select Import.
  2. In the displayed dialog box, click Download Template.
    The import template file is displayed in the lower part of the page. Save the file to the local PC and fill in data. The template file should be named in the following format: Project name + "-" + Module name (for example, Task) + Template.
  3. Fill in the fields on the Task - List sheet.
    For details about how to set parameters, see the Task - Import Rules sheet in the template file.
  4. Drag or click to select a file to be imported.
  5. Click Import. The import progress dialog box is displayed.
    • After the import is successful, you can view the imported task information in the task list.
    • If the import fails, a message is displayed in the upper right corner of the page. Click View Failure Details in the message to view the failure details. You can modify the requirement information based on the details and import the template again.
      For details about operations on import records, see Viewing Work Item Import/Export Records.
Export work items
Export requirements in batches to an Excel file.
  1. Export some or all tasks.
    • Export all: On the Tasks page, click on the right of the search bar and choose Export All. The Select Fields to Export dialog box is displayed.
    • Export some: In the task list, select one or more tasks to be exported and click Export Selected at the bottom of the page. The Select Fields to Export dialog box is displayed.
  2. Select the fields to be exported and determine whether to export child tasks.
  3. Click Export. A dialog box is displayed, indicating the export progress.
    • After the tasks are exported, click Download. The task file will be downloaded to the local PC. The file format is .xlsx.
      For details about operations on export records, see Viewing Work Item Import/Export Records.
Configure fields to display
Click next to the Operation field.
  • On the left of the pop-up box, select the fields to be displayed.
  • On the right of the pop-up box, drag the fields in the Selected area to adjust the display sequence.
Clone items across projects
  • Only tasks can be cloned. The workload, associated work item, tag, and release sprint fields will be cleared.
  • You must have permission to create and clone tasks for the target project.
  • Tasks can be cloned only to projects of the same type.
  • You can clone up to 50 tasks at a time.
  1. Select the tasks to clone in the task list and click Cross-Project Copy in the lower part of the page. The Cross-Project Copy window is displayed.
  2. Select a target project from the drop-down list. You can select only a project to which you have joined and must have permission to create and clone tasks for the target project.
  3. Click Next. The window for setting mandatory fields is displayed. Select the target owner from the drop-down list (the current operator is selected by default). Mandatory fields are those on the task creation page of the target project.
  4. Click OK. The tasks are cloned to the target project.
  5. Go to the target project to view the cloned tasks.
Transition statuses in batches
  • The selected tasks must be in the same status.
  • You must have permission to set statuses for tasks.
  • Mandatory fields of the selected tasks are all filled.
  1. Select the target tasks in the task list and click Batch Transfer in the lower part of the page. The Batch Transfer window is displayed.
  2. Select the target status from the drop-down list.
  3. Click Next.
  4. Set mandatory fields. The mandatory fields are set on the In-transition GUI Config tab page of the project's task status flow configuration page.
  5. Click OK.
Perform batch operations
You can select multiple tasks to perform operations in batches: edit, suspend/unsuspend, export, delete, cross-project clone, and transition.
Group tasks
You can group work items by any supported field type.
  • A maximum of 1,000 work items can be displayed during grouping.
  • The supported field types include single-choice list, multi-choice list, single-choice user, multi-choice user, hierarchy, and date.
  • For projects in a program (after sub-project aggregation is enabled), grouping by release, sprint, module, feature set, or tag is unavailable.
  1. On the Tasks page, click Group.
  2. On the displayed page, select the fields used to group work items.
    • You can sort work items in ascending or descending order.
    • You can enter a keyword to search for fields.
    • When work items are grouped by multi-select list or multi-select user, the same work item may appear in multiple groups.
    • You can click No grouping to ungroup work items.
On the Task Details Page
On the details page of a task, you can modify the description, priority, and owner, add tags and attachments, associate work items, design models, check review records, add workloads, and view the operation history.
Table 2 Management operations on the details page
Operation
Remarks
Edit work item
On the task details page, click the value box of the field to be modified, and enter a target value in the text box or select one from the drop-down list. The modification is saved automatically.
You must have permission to edit tasks.
Change work item status
Go to the work item details page, click the Status field, and transition the work item to the target status. For details about status transition, see Table 1.
Upload attachment
Attachments can be pictures, workbooks, manuscripts, and text files. A maximum of 100 attachments can be added to each work item, and their total size cannot exceed 500 MB.
  1. Go to the work item details page, and click the Attachment tab.
  2. Click the box to select a local file or drag the file here to upload it as an attachment for the work item.
    Local files can be directly dragged to the text box. When the upload progress reaches 100%, the system displays a message indicating that the attachment is uploaded successfully.
    Move the cursor to the file that is successfully uploaded. The operations that can be performed are displayed.
    • Click to download the file.
    • Click to delete the uploaded file.
You must have permission to upload attachments for tasks.
Add and check related item
A work item can be associated with other types of work items in a project.
  1. Go to the work item details page and click the Related Items tab.
  2. Complete association.
    • Parent Task: parent task to which a task belongs.
      You can choose Associated Items > Parent Task of a child task to view the task only when the task contains child tasks.
    • Child Task: tasks included in the current task.
      A maximum of 10 child requirements can be created at a time. One child requirement is displayed by default and cannot be deleted.
      1. Click Break Down. The Break Down Child Tasks window is displayed.
      2. Configure the information about the child task. Click to expand and configure more information.
      3. Click OK. The child task is created successfully. The child task is automatically displayed under the parent task in the task list.
    • Associate Work Item: associated work items of other types in the project.
      Work items of the RR, SF, IR, SR, AR, and bug types can be associated.
    • Associated open issue review form: reviews that include the review and approval comments related to the work item.
    • Code Commit Record: code commit records related to the task.
      Related information is displayed only when the current task is associated during code commit.
    • Code Branch: code branch corresponding to a task.
      Related information is displayed only when a code branch is associated with the current task.
    • Code Merge & Change Request: code merge and change requests corresponding to a task.
      Related information is displayed only when a submitted merge or change request is associated with the current task.
You must have permission to associate/dissociate parent task, create subtasks, associate/dissociate work items, associate/dissociate files, and associate/dissociate wikis for tasks.
Add workload
  1. Go to the work item details page and click the Workload tab.
  2. Click Add Workload. The Add Workload dialog box is displayed.
  3. Enter the workload information.
    • The end date cannot be earlier than the start date.
    • Decide whether to select Weekends included. If not, weekend workload records will not be generated.
    • You can select Total or Daily for Workload.
    • Work Type options include backend development, frontend development, UI design, replacement leave, debugging, and general. You can also customize the value by referring to Creating Work Types.
  4. Click OK.
    The system automatically generates corresponding records based on the entered dates and days.
    The workload can be edited and deleted.
You must have permission to add person-hours for tasks.
Workloads can be edited and deleted by the creator. By default, the project administrator can edit and delete all workloads.
View operation history
History displays all operation logs of users, including creation, status transition, review initiation, work item association, and workload addition.
  1. Go to the work item details page.
  2. Click the History tab.
    • Click or to check historical records in the ascending or descending order of operation time.
    • You can set search criteria to query historical records that meet the search criteria.
You must have permission to view tasks.
Tag work item
  1. Go to the work item details page. Click next to Tag at the top of the page, and select Create Tag.
    The added tag is displayed in the Tag area.
  2. In the Create Tag dialog box, set Tag Name and select Tag Color.
  3. Click OK.
    The new tag is displayed next to the task ID in the task list.
  4. (Optional) Hide a tag.
    • Click next to Tag. In the displayed dialog box, deselect to hide the tag.
    • Move the cursor to the tag name and click to hide the tag.
      Figure 2 Hiding a tag - 02
      To add or remove tags for multiple work items, select the desired work items, click Batch Edit in the lower part of the page, and select Tag.
Add attachment
Perform the following operations to add attachments to a work item. You can upload/drag-and-drop a local file or choose a file in CodeArts Wiki.
  1. Access the page for creating or editing a work item.
  2. Click to add attachments to the work item. The maximum size of attachments for a single work item is 500 MB.
Add comment
  2. On the Details tab page, click the Comments text box.
    Figure 3 Add comment
  3. Enter a comment.
    You can upload images, enter links, associate work items, and use @ to notify project members in comments.
  4. Click Submit.
    Submitted comments can be replied, edited, pinned to the top, and deleted.
