(Optional) Checking Audit Logs
Cloud Trace Service (CTS) records operations on CodeArts Req for query, audit, and backtrack.
Operations Recorded by CTS
Operation | Resource Type | Event |
Create a permission template | privilege_template | addPrivilegeTemplate |
Delete a permission template | privilege_template | deletePrivilegeTemplate |
Modify the name or description of a permission template | privilege_template | updatePrivilegeTemplateNameOrDescription |
Modify the specific permissions in a permission template | privilege_template | updatePrivilegeTemplate |
Apply a permission template to a project | privilege_template | applyPrivilegeTemplate |
Add a user to a role | role_user | addUsersToRole |
Delete a user from a role | role_user | deleteUsersFromRole |
Modify role permissions | role_privilege | updatePrivilegeOfRole |
Add users in batches to a project | project | batchAddRoleUserRelation |
Modify users in batches in a project | project | batchUpdateRoleUserRelation |
Delete users in batches from a project | project | batchDeleteRoleUserRelation |
Create a project | project | createProject |
Update the project name | project | updateProjectName |
Update the project creator | project | updateProjectCreator |
Update project description | project | updateProjectDescription |
Delete a project | project | deleteProject |
Archive a project | project | archiveProject |
Cancel archiving a project | project | unArchiveProject |
Set member reviewers | member | setAuditSwitchOfInvitateMember |
Add a project member | member | addProjectMember |
Remove a project member | member | deleteProjectMember |
Update a project member role | member | updateProjectMemberRole |
Create a custom role | role | createProjectRole |
Update a custom role name | role | updateProjectRoleName |
Delete a custom role | role | deleteProjectRole |
Update permissions of a custom role | role | updateProjectRolePermission |
Create a common field | issue | createProjectCommonField |
Delete a common field | issue | deleteProjectCommonField |
Update a common field | issue | updateProjectCommonField |
Create a common status | issue | createProjectCommonState |
Delete a common status | issue | deleteProjectCommonState |
Update a common status | issue | updateProjectCommonState |
Create a module | issue | createProjectModule |
Create a submodule | issue | createProjectChildModule |
Delete a module | issue | deleteProjectModule |
Update a module | issue | updateProjectModule |
Create a domain | issue | createProjectDomain |
Delete a domain | issue | deleteProjectDomain |
Update a domain | issue | updateProjectDomainName |
Add a custom field to a project | issue | addProjectFieldFor |
Create a custom field for a project | issue | createProjectFieldFor |
Add a custom status to a project | issue | addProjectStateFor |
Delete a work item | issue | deleteProjectIssue |
Checking Audit Logs
Query CodeArts Req traces on the CTS console. For details, see viewing audit events.
