Updated on 2025-08-13 GMT+08:00
PipelineSuspension
Call the PipelineSuspension extension to suspend the current pipeline.
Adding the Extension with GUI
Add the PipelineSuspension extension when you orchestrate a pipeline. Set parameters as shown in Table 1.
Table 1 Parameter description
Name
Extension name, which can be customized.
  • Enter only letters, digits, hyphens (-), underscores (_), commas (,), semicolons (;), colons (:), periods (.), slashes (/), parentheses (), and spaces.
  • Enter 1 to 128 characters.
Adding the Extension with YAML
Add the PipelineSuspension extension when you orchestrate a pipeline. Configure the YAML syntax as follows:
  • PipelineSuspension
    uses: SuspendPipeline
