Build
Call the Build extension to use CodeArts Build capabilities.
Adding the Extension with GUI
Add the Build extension when you orchestrate a pipeline. Set parameters as shown in Table 1.
Parameter |
Description |
Name |
Extension name, which can be customized.
Project Config |
Select the current project or other projects. |
Select Project |
If you set Project Config to other projects, select a project to be called. |
Select Task |
Select a build task whose code source is pipeline or the same repository as the pipeline you are configuring. |
Repository |
Select the corresponding code repository. |
Artifact Identifier |
Identifier of each build artifact. For example, if the ID of the build task is "build_job" and the artifact identifier is "demo", use "${{jobs.build_job.artifacts.demo}}" to obtain artifact information in subsequent tasks. |
Adding the Extension with YAML
Add the Build extension when you orchestrate a pipeline. Configure the YAML syntax as follows:
- Build
uses: CodeArtsBuild with: jobId: 878b4d13cb284d9e8f33f988a902f57c artifactIdentifier: my_pkg customParam: value
- jobId: ID of the build task. To obtain the ID, copy the 32 digits and letters at the end of the browser URL on the build task details page.
- artifactIdentifier: Build artifact identifier.
- customParam: Parameter value defined in the build task. There may be zero to multiple values.
