Checking the Dashboard
The pipeline statistics dashboard displays pipelines, their execution statuses, parallel executions in the system and in each project.
You have enabled and authorized CodeArts Pipeline.
- Access the CodeArts Pipeline homepage.
- The dashboard displays pipeline statistics.
Table 1 Pipeline statistics Item
Pipelines
Total number of pipelines.
Executions
Execution success rate and execution times. You can check executions within 90 days.
Parallel Executions
Number of queuing and running parallel instances.
- Click
on the right of the queuing instances. The Queuing Instances window is displayed for you to check the queuing pipelines and triggers. - Click
on the right of the running parallel instances. The Running Instances window is displayed for you to check the names, execution information, triggers, and execution time of running pipelines.
Pipelines per Project
Number of pipelines in each project. You can click a project name to access pipelines in this project.
Executions per Project
Execution success rate and execution times in each project. You can check executions during a specified period. You can also click a project name to access pipelines in this project.
Parallel Executions per Project
Number of queuing and running parallel instances in each project.
- Click
