Updated on 2025-10-10 GMT+08:00
Executing a Pipeline
You can check the pipeline execution progress, logs, and results in real time.
- You have enabled and authorized CodeArts Pipeline.
- Your role is a project administrator or pipeline creator. For details about how to configure permissions, see Authorizing CodeArts Pipeline.
- Access the CodeArts Pipeline homepage.
- Search for the target pipeline, click
in the Operation column, and select Manual Execution.
- In the displayed window, set the following parameters:
- Pipeline Source: Select the branch or label of the code source.
- Runtime Parameters: (Optional) Set runtime parameters. For details, see Configuring Pipeline Parameters.
- Execution Stages: Select one or more jobs to execute. By default, all jobs are executed.
If Always Run is set to Yes for a stage, jobs in this stage will be selected for execution by default and cannot be canceled.
- Description: Describe the execution.
- Click Execute. On the pipeline details page, you can check the execution progress and job status in real time.
Figure 1 Executing a Pipeline
- Click Retry to execute the failed job again.
- Click
on the card of the failed job to re-execute the job.
- Click Re-execute to execute the pipeline with the new configuration.
- Click Stop in the upper right corner to stop the execution.
- Click Edit to change the pipeline configurations.
- A pipeline can have multiple concurrent executions. You can click Execute to start a new execution of the pipeline. The maximum number of concurrent pipeline executions varies based on your purchase. For details, see CodeArts Pipeline specifications.
- After the execution is complete, you can check the execution result. If you encounter any problem during the execution, see Troubleshooting.
