- What's New
- Function Overview
- Getting Started
User Guide
- CodeArts Pipeline Usage
- Enabling and Authorizing CodeArts Pipeline
- Accessing CodeArts Pipeline
- Creating a Pipeline
- Configuring a Pipeline
- Grouping Pipelines
- Executing a Pipeline
- Checking a Pipeline
- Configuring a Change-triggered Pipeline
- Managing Pipeline Extensions
- Creating Service Endpoints
- Checking Audit Logs
- Reference
- CodeArts Release User Guide
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Template Management
Pipeline Management
- Starting a Pipeline
- Obtaining Pipeline Statuses in Batches
- Obtaining Pipeline Status/Obtaining Pipeline Execution Details
- Obtaining Pipeline List/Pipeline Execution Status in a Project
- Deleting a Pipeline
- Querying Pipeline Details
- Editing a Pipeline
- Stopping a Pipeline
- Obtaining Pipeline Execution Records
- Creating a Pipeline With a Template
- Retrying a Pipeline
- Passing Manual Review
- Rejecting Manual Review
- Querying Pipeline Logs
- Obtaining the Pipeline Step Execution Output
- Querying Build Products on a Pipeline
- Group Management
- Rule Management
- Tenant-level Policy Management
- Project-level Policy Management
Extension Management
- Creating an Extension Version
- Creating an Extension Draft Version
- Creating a Publisher
- Updating an Extension Draft
- Publishing an Extension Draft
- Updating Basic Information of an Extension
- Binding an Extension to a Publisher
- Updating the Extension Icon
- Updating the Publisher Icon
- Deleting an Extension Draft
- Querying the Publisher List
- Querying the Available Publisher
- Querying the Available Extension List
- Querying the Basic Extension List
- Querying the Available Extensions by Page
- Querying the Extension List
- Querying Extension Indicator Configuration
- Query Extension Input Configuration
- Query Extension Output Configuration
- Querying All Versions of an Extension
- Querying Extension Version Details
- Querying the Extension Version
- Deleting a Publisher
- Querying Publisher Details
- Creating a Basic Extension
- Updating a Basic Extension
- Deleting a Basic Extension
- Uploading a Basic Extension
- Querying the Basic Extension Details
- Template Management (Old Version, Unavailable Soon)
Pipeline Management (Old Version, Unavailable Soon)
- Quickly Creating a Pipeline and Jobs with a Template
- Checking the Pipeline Creation Status
- Obtaining the Pipeline List
- Obtaining the Pipeline Status
- Obtaining the Pipeline Execution Status in a Project
- Application Examples
- Appendixes
- Change History
- Functions
Troubleshooting
- Pipeline Fails to Run Because Repository Not Found
- Pipeline Fails to Run Because the Test Suite Is Already in Progress
- Pipeline Fails to Run Because Job Not Found
- Pipeline Is Not Triggered at a Specified Time
- Execution Button Is Unavailable
- Inappropriate Reviewer Configured for the Manual Review Job
- Subpipeline Not Found
- Change-triggered Pipeline Fails to Run and an Error Message Is Returned: "authentication required"
- Pipeline Fails to Run Because Deployment Policy Not Found
- Videos
Configuring an Environment Variable
You can use ${variable name} to reference an environment variable when creating or editing a release policy, or use {{variable name}} to reference an environment variable in YAML files. Environment variables include:
- Custom variables: can be added as needed. Currently, only variables of the string type are supported.
- Default variables: system parameters, which cannot be deleted or modified.
Table 1 Default variables Variable
ARTIFACT
Artifact path. In the deployment YAML file, use {{ARTIFACT}} to reference the build artifacts.
TIMESTAMP
Timestamp when the extension is executed. For example, 20230401095436.
PROJECT_ID
ID of the project to which the environment belongs.
- Access the release environment list page.
- Click an environment name. The Environment Information page is displayed.
- Click the Environment Variable tab.
- Click Edit Variable to add a variable and set parameters.
Table 2 Parameters for creating a custom variable Parameter
Variable
Variable name. Enter only letters, digits, underscores (_), and hyphens (-) with a maximum of 128 characters.
Type
Only the string type is supported.
Value
The current value of a variable, or empty if you are adding a new variable. The value contains no more than 512 characters.
Change Value
Updated value of the environment variable.
Variable description. It can contain a maximum of 128 characters.
Private Variable
If a parameter is private, the system encrypts the parameter for storage and decrypts the parameter for usage. Private parameters will not be displayed in run logs.
- Click
in the Operation column to delete a variable.
- Click
to add a variable.
- Click
- After setting all parameters, click Save. The Save Changes dialog box is displayed.
- Confirm the variable information, enter the remarks, and click OK.
You can click the Versions tab to check variable versions.
- Click a version name to view the variable details.
- Click
in the Operation column to compare the current version with a specified version.
Using an Environment Variable
You can use environment variables in the following scenarios:
- When configuring a release policy, you can use ${variable name} to reference an environment variable in the YAML path, for example, the workload YAML path in the rolling upgrade task.
Figure 1 Referencing an environment variable
- Use {{variable name}} to reference an environment variable in the YAML configuration file associated with the release policy.
Figure 2 Referencing an environment variable
