on
Use on to specify events that automatically trigger a pipeline. These events include changing branches, files, and tags, and executing scheduled tasks.
on.<event_name>.types
Use on.<event_name>.types to specify the type of a merge request (MR) event that can trigger a pipeline.
MR Type |
Description |
opened |
An MR is created. |
synchronize |
The source branch is updated. |
closed |
An MR is merged. |
reopened |
An MR is reopened. |
If you do not define a type, the pipeline will be triggered when an MR is opened, synchronized, or reopened. The following example shows the syntax for triggering a pipeline when an MR is closed.
1 2 3 4 |
on: pull_request: types: - closed |
on.<pull_request>.<branches|branches-ignore>
Use the pull_request event to define a pipeline to run for MRs that target specific branches.
- branches: Use branches to include specific branches, or both include and exclude specific branches.
- branches-ignore: Use branches-ignore to exclude specific branches.
Do not use branches and branches-ignore for a pull_request event at the same time.
branches and branches-ignore support the use of glob patterns to match branch names.
Character |
Description |
Example |
Matches zero or more characters, except the slash (/). |
dev*: matches dev and develop, but cannot match dev/test. |
Matches one character. |
dev?: matches dev1 and dev2, but cannot match dev12. |
Matches zero or more characters. |
dev**: matches dev, develop, and dev/test. |
Matches one character listed in or within the specified range in the brackets. Ranges only include a-z, A-Z, and 0-9. |
Matches strings listed in the parentheses. |
{branch1,branch2}: matches branch1 and branch2. |
It is at the start of a string, indicating that the subsequent characters are not matched. |
!develop: matches all characters except develop. |
Example
- Including branches
on: pull_request: branches: - master - 'release**'
This example indicates that the pipeline would run when there is a pull_request event that targets the following branches:
- a branch named master, or;
- a branch whose name starts with release, for example, release, release-1.0.0, and release/1.0.0
- Excluding branches
on: pull_request: branches-ignore: - test - 'dev**'
This example indicates that the pipeline would run when there is a pull_request event, unless the event targets the following branches:
- a branch named test, or;
- a branch whose name starts with dev, for example, dev, develop-1.0.0, and develop/1.0.0
- Both including and excluding branches
Use branches and an exclamation mark (!) to both include and exclude specific branches.
on: pull_request: branches: - 'release**' - '!release/v1**'
This example indicates that the pipeline would run when there is a pull_request event, and the event's targeting branches meet all of the following conditions:
- a branch whose name starts with release, for example, release, release-1.0.0, and release/1.0.0.
- a branch whose name does not start with release/v1/**, for example, release/v1, release/v1.0, and release/v1/1.0.
on.<push>.<branches|branches-ignore|tags|tags-ignore>
Use the push event to define a pipeline to run on specific branches or tags.
- tags: Use tags to include specific tags, or both include and exclude specific tags.
- tags-ignore: Use tags-ignore to exclude specific tags.
- Do not use branches and branches-ignore for a push event at the same time.
- Do not use tags and tags-ignore for a push event at the same time.
Example
- Including branches/tags
on: push: branches: - master - 'release**' tags: - v1 - 'v2.*'
This example indicates that the pipeline would run when there is a push event that targets the following branches and tags:
- a tag named v1
- a tag whose name starts with v2., for example, v2.1 and v2.1.1
- Excluding branches/tags
on: push: branches-ignore: - test - 'dev**' tags-ignore: - v1 - 'v2.*'
This example indicates that the pipeline would run when there is a push event, unless the event targets the following branches and tags:
- a branch whose name starts with dev, for example, dev, develop-1.0.0, and develop/1.0.0.
- a tag named v1
- Both including and excluding branches/tags
Use branches, tags, and an exclamation mark (!) to both include and exclude specific branches and tags.
on: push: branches: - 'release**' - '!release/v1**' tags: - 'v1**' - '!v1.1'
This example indicates that the pipeline would run when there is a push event, and the event's targeting branches and tags meet all of the following conditions:
- a tag whose name starts with v1, for example, v1 and v1.2
- a tag whose name is not v1.1
on.<push|pull_request>.<paths|paths-ignore>
Use the push and pull_request events to define a pipeline to run when specified files change.
- paths: Use paths to include specific files or both include and exclude specific files.
- paths-ignore: Use paths-ignore to exclude specific files.
Do not use paths and paths-ignore for push and pull_request events at the same time.
Example
- Including files
on: push: paths: - '**.java'
This example indicates that the pipeline would run when you push a .java file.
- Excluding files
on: push: paths-ignore: - 'docs/**'
This example indicates that the pipeline would run when there is a push event, unless all pushed files are in the docs directory.
- Both including and excluding files
Use paths and an exclamation mark (!) to both include and exclude specific files.
on: push: paths: - 'src/**' - '!src/docs/**'
This example indicates that the pipeline would run when the changed files are in the src directory or its subdirectories, but not in the src/docs directory.
on.schedule
Use on.schedule to schedule a pipeline to run at a specified UTC time by defining a cron expression. The pipeline will run based on the lasted scheduled task information. To update the scheduled task, edit YAML and save it. The default branch of the pipeline source is used.
on: schedule: - cron: '0 0 12 * * ?' - cron: '0 0 20 * * ?'
The above example indicates that the pipeline would run at 12:00 and 20:00 (UTC time) every day.
