Knowledge Base Hit Test
The platform supports the hit test on the created knowledge base to evaluate the effectiveness and accuracy of the knowledge base.
The hit test matches the user's query with the content in the knowledge base, provides the related information, and sorts the information based on the matching degree.
The knowledge base hit test procedure is as follows:
- Log in to the agent development platform.
- On the Knowledge tab page of the Workstation page, click the required knowledge base, and click Hit Test in the upper right corner.
- Enter a question in the text box and click Hit Test. The lower part of the page displays multiple matched contents according to different search modes and sorts the content in descending order by matching score.
You can evaluate whether the current knowledge base meets the requirements based on the score and the amount of matched information.
- Click View History to view the historical questions entered by the user.
Figure 1 Viewing history
