Configuring a Plug-in
The agent development platform provides a rich plug-in ecosystem to enhance the functions of the agents. A plug-in is an API tool. Currently, the platform integrates various plug-ins, including file processing, code interpreter, network-wide hot search rankings, and AutoNavi Map. These plug-ins can help developers quickly add specific functions to an agent. In addition, you can create custom plug-ins to quickly integrate existing API capabilities into the agent through parameter configuration, further enriching their functions.
Constraint |
Description |
Maximum number of plug-ins |
20 |
Plug-in URL |
The URL protocol can only be HTTP or HTTPS. |
Request method |
The request method of the plug-in service can be POST or GET. |
Adding a Preset Plug-in
Plug-in skills can be added to agents. Preset plug-ins and personal plug-ins can be added.
If you want to add a personal plug-in, ensure that the personal plug-in has been created.
To add a plug-in, perform the following steps:
- Click the application. In the Plugin area of the skill pane of the application configuration page, click
. - In the Add plugins dialog box, select a preset plug-in, click
on the preset plug-in card, and click OK. - After adding a plug-in, you can view it in the skill > Plugin area.
Figure 1 Adding a preset plug-in
Creating a Personal Plug-in
. - In the Add plugins dialog box, select a personal plug-in, click
on the plug-in card, and click OK. - If no personal plug-in is available, click Create plugin in the upper right corner to create one and then add it.
- After adding a plug-in, you can view it in the skill > Plugin area. For details about how to create a plug-in, see Managing Plug-ins.
Figure 2 Adding a personal plug-in
Removing a Plug-in
- In the skill > Plugin area, click
on the plug-in to be removed. - If the message Deleted plugin successfully. is displayed, the plug-in has been removed.
Figure 3 Removing a plug-in
