Updated on 2025-11-04 GMT+08:00
Format Conversion Process
  1. Log in to ModelArts Studio. In the My Spaces area, click the required workspace.
    Figure 1 My Spaces
  2. In the navigation pane, choose Data Engineering > Data Acquisition > Data Import. On the displayed page, click Create Import Job in the upper right corner.
  3. On the Create Import Job page, set Dataset Type to Other > Customization. Import the dataset to be converted, as shown in Figure 2.
    Figure 2 Importing data
  4. In the navigation pane, choose Data Engineering > Data Processing. On the Processing Tasks page, click Manage Processing Operator, and click the Custom tab page, as shown in Figure 3.
    Figure 3 Creating a custom operator
  5. Import the corresponding YML file and TAR package to build a format conversion operator.
  6. In the navigation pane, choose Data Engineering > Data Processing. On the Processing Tasks page, click Create Processing Job.
  7. Select a dataset and a conversion operator to start the format conversion task.
  1. Object detection and image classification support the JPG, JPEG, BMP, PNG, TIF, and TIFF formats.
  2. The CSV file is in UTF-8 format and the content to be read is on the first sheet.
