Supported Dataset Types
Custom dataset structure: Image suffixes (jpg, jpeg, png, bmp, tif, and tiff) are supported.
Assume that the name of the customized dataset file is test_customized dataset.
+---test_Custom dataset
| +---Image 001 # Python operator directory
| +---Image 002 # Python operator directory
| +---Image 003 # Python operator directory
| +--- CSV file
Supported CV Dataset Types
Only custom datasets can be converted into image (object detection and image classification) datasets.
