Updated on 2025-07-02 GMT+08:00
Format Requirements for Audio Datasets
ModelArts Studio supports the creation of audio datasets. During the creation, you can import data in various formats. Table 1 lists the format requirements.
Table 1 Format requirements for audio datasets
File Content
File Format
Requirement
Audio Only
Audio
  • Supported formats: mp3, flac, wav, opus, aac, and m4a. All audio files can be stored in multiple folders. Each folder can contain audio files in different formats.
  • Import from OBS: The size of a single file cannot exceed 50 GB, and the number of files is not limited.
Audio + Annotation
Audio + JSONL
  • Supported audio formats: mp3, flac, wav, opus, aac, and m4a
    Annotation file format: JSONL
The following is an example.
For details about the annotation file in JSONL format, refer to the following:
{"audio_name":"dir/16k_16bit_1channel_2s.flac","caption":"1"}
{"audio_name":"dir/16k_16bit_1channel_2s.mp3","caption":"2"}
{"audio_name":"dir/16k_16bit_1channel_2s.opus","caption":"3"}
{"audio_name":"dir/16k_16bit_1channel_2s.wav","caption":"4"}
