Updated on 2025-07-28 GMT+08:00
Compressing a DeepSeek Model
Before model deployment, perform model compression, so less video memory is needed during inference and inference performance is improved. By compressing a third-party large model, the storage size of the model can be reduced, power consumption can be decreased, and computational speed can be improved.
  1. Log in to ModelArts Studio. In the My Spaces area, click the required workspace.
    Figure 1 My Spaces
  2. In the navigation pane, choose Model Development > Model Compression. Click Create in the upper right corner. Create a model compression task by referring to Table 1.
    Table 1 Parameters for creating a model compression task
    Category
    Parameter Name
    Compression Configuration
    Model Source
    Select Third-party large model.
    Base Model
    Select the model to be compressed. You can use a model from assets or jobs.
    Compression Policy
    Select INT8.
    Resource Disposition
    Resources Pool
    Select the resource pool used by the model compression task.
    Subscription reminder
    After this function is enabled, the system sends SMS or email notifications to users when the task status is updated.
    publish model
    Enable automatic publishing
    If this function is disabled, the model will be manually published to the model asset library after the training is complete.
    If this function is enabled, configure the visibility, model name, and description.
    Basic Information
    Task name
    Name of a model compression task.
    Compressed model name
    Name of the compressed model. (This configuration item is available only when Enable automatic publishing is disabled.)
  3. After setting the parameters, click Create Now.
