Updated on 2025-11-04 GMT+08:00
Processing Other Datasets
Before processing a dataset of other types, import data. For details, see Importing Data to the Pangu Platform.
Creating an Other-Type Dataset Processing Task
To create a processing task for a dataset of other types, perform the following steps:
  1. Log in to ModelArts Studio Large Model Deveopment Platform. In the My Spaces area, click the required workspace.
    Figure 1 My Spaces
  2. In the navigation pane, choose Data engineering > Data Processing > Processing Tasks. Click Create Processing Job in the upper right corner.
  3. On the Create Processing Job page, select the other type of dataset to be processed and click Next.
  4. Go to the processing step arrangement page.
    1. In the Adding Operator pane on the left, select the required operators. You can select one or more operators based on the actual scenario.
      For other types of datasets, the platform supports only custom operators. For details about how to create a custom operator, see Custom Data Processing Operators.
    2. On the processing step orchestration page on the right, set operator parameters. You can drag on the right to adjust the operator execution sequence.
    3. During orchestration, you can click Save as template in the upper right corner to save the current orchestration process as a template. When creating a data processing task, you can use the saved template to create the task. For details, see Using a Processing Template.
  5. After the processing steps are orchestrated, click Start Process to start the processing task.
    After the data processing job is successfully executed, the status changes from Running to Succeeded, indicating that the data has been processed.
  6. After data processing is complete, click Generate in the Operation column on the Processing Task page to generate a processed dataset.
    To view the processed dataset, choose Data Engineering > Data Management > Datasets, and click the Processed Dataset tab.
