Managing Published Datasets
If you have completed data combination or data circulation tasks for a dataset, click Generate in the corresponding task list to generate a published dataset. The generated datasets are managed by the platform in a unified manner and used for subsequent publishing tasks.
The platform allows you to view basic information and data lineage of published datasets. The procedure is as follows:
- Log in to ModelArts Studio Large Model Deveopment Platform. In the My Spaces area, click the required workspace.
Figure 1 My Spaces
- In the navigation pane, choose Data Engineering > Data Management > Datasets. Click the Published Dataset tab.
- You can search for and filter datasets by dataset name, dataset modality, and dataset property name.
Figure 2 Dataset filtering type
- Click the dataset name to view the basic information, data preview, data lineage, and operation records of the published dataset.
- On the Basic Information tab page, you can view the data details, data source, and extended information. In the Extended Info area, you can set dataset properties as required, including the dataset property name, industry, language, and custom tag, as shown in Figure 3.
Figure 4 Editing extended information
- On the Data Preview tab page, you can view the published data.
- On the Data Lineage tab page, view the operations performed on the dataset, such as import and synthesis. The data lineage is drilled up to the OBS source file and drilled down to the model training.
- On the Operation Record tab page, view the operations and status of the dataset.
- Click Delete in the Operation column to delete unnecessary datasets.
- To restore a deleted dataset, click Show Deleted Data in the upper right corner. In the list of deleted datasets, restore the dataset.
- To permanently delete a dataset, click the dataset name to go to the dataset details page, confirm the dataset content, and delete it permanently.
Deleting a published dataset is a high-risk operation. Before deleting a dataset, ensure that it is no longer used.
