Updated on 2025-07-28 GMT+08:00
Labeling Text Datasets
Creating a Text Dataset Labeling Task
Before labeling a text dataset, import data. For details, see Importing Data to the Pangu Platform.
The data labeling function allows you to create annotation tasks, label datasets (annotation tasks), review labeled datasets (review tasks), and manage annotation tasks (task management). The functions supported by different roles and the displayed frontend pages are slightly different. For details, see Table 1.
Table 1 Data labeling task permissions supported by different roles
Role Name
Labeling Task Creation
Labeling Task
Labeling Review
Labeling Task Management
Super Admin
Administrator
Annotation administrator
Annotation operator
Annotation auditor
To create a text dataset annotation task, perform the following steps:
  1. Log in to ModelArts Studio Large Model Deveopment Platform. In the My Spaces area, click the required workspace.
    Figure 1 My Spaces
  2. In the navigation pane, choose Data Engineering > Data Processing > Data Labeling. On the displayed page, click Create annotation task in the upper right corner.
  3. On the Create annotation task page, select the text dataset to be annotated and select annotation items. The annotation items vary depending on the data file type. You can select annotation items as prompted.
    The single-turn Q&A annotation items support the AI-assisted annotation function. If this function is enabled, you need to select a deployed NLP service as the AI-assisted annotation model.
  4. You can enable the multiplayer job function. After this function is enabled, you can select multiple persons to complete the operation. In addition, the review function can be enabled if required. Configure labeling assignment and review by referring to Table 2.
    Table 2 Labeling assignment and review configuration
    Category
    Parameter Name
    Labeling assignment
    Annotator
    Add annotators and the number of annotations.
    Labeling review
    Is reviewed
    • No: The review operation is not performed after labeling.
    • Yes: The reviewer checks the annotation content of the annotator. If any problem is found, the reviewer can specify the reason and reject the annotation data. The annotator needs to label the data again.
    Reviewer
    Add reviewers and the number of reviewers.
    Review requirements
    • Full review: The reviewer needs to manually review all data records one by one.
    • Partial review: If the labeling quality of some data is high, the reviewer can submit the remaining data for review in one-click mode. By default, the data is approved and the review task is complete.
  5. After the configuration is complete, click Complete creation.
  6. On the Annotation Task page, click Work in the Operation column of the current labeling task to execute the task.
    For the "Annotate operators" role, you can click Annotation to execute the job.
    If you need to transfer the labeling task to other personnel, click Transfer, set the transfer personnel and quantity, and click OK.
  7. On the labeling page, label data record one by one.
    As shown in Figure 2, if the data of a single-turn Q&A is labeled, you need to check whether the question (Q) and answer (A) are correct one by one. If the question or answer is incorrect, you can edit the question or answer again.
    Figure 2 Example of labeling a text dataset
  8. After labeling a piece of data, click Submit to label the remaining data. After all data is labeled, a message is displayed, indicating that the labeling task is successful.
After data labeling is complete, if you do not need to review the labeling result, click Generate on the Annotation Task > Task Management page to generate a processed dataset.
To view the processed dataset, choose Data Engineering > Data Management > Datasets, and click the Processed Dataset tab.
AI-assisted Labeling
In a labeling task, the labeler can use intelligently generated label for a single data record. The procedure is as follows:
  1. On the Create Annotation Task page, select a dataset, enable AI-assisted annotation, and click Complete creation.
    Figure 3 AI-assisted labeling
  2. On the Annotation Task page, click Work in the Operation column of the task to access the labeling page.
    Figure 4 Labeling tasks
  3. Click the Settings button, modify the AI labeling model, and click OK.
    Figure 5 Settings
  4. Click Regenerate to generate a new answer.
    Figure 6 Regenerate
  5. Click Apply. The regenerated content is displayed in the answer box.
    Figure 7 Apply
Reviewing a Labeled Text Dataset
If the labeling review function is enabled in Creating a Text Dataset Labeling Task, the labeling result can be reviewed after the labeling is complete. If the data fails to pass the review, you can enter the failure cause and reject the data to the annotator for re-labeling.
You must have the permission of the Annotate auditors role.
To review the labeling result of a text dataset, perform the following steps:
  1. Log in to ModelArts Studio. In the My Spaces area, click the required workspace.
    Figure 8 My Spaces
  3. Click Review to go to the review page and review the data.
    If you want to transfer the review task to another person, click Transfer, set the transferee and transfer quantity, and click OK.
  4. On the review page, you can click Approve or Reject to review the data record one by one until all data is reviewed.
After the data labeling review is complete, click Generate on the Annotation Task > Task Management page to generate a processed dataset.
Managing Labeled Text Datasets
The platform allows super administrators, administrators, and labeling administrators to perform the following operations on labeled datasets:
  • Generate: After data labeling is reviewed, the super administrator, administrator, or labeling administrator needs to click Generate in the Operation column on the Annotation Task page to generate a processed dataset.
  • Stop: The administrator can click More > Stop in the Operation column on the Annotation Task page to stop the current labeling task.
  • Edit: If the labeling job supports the AI-assisted annotation and review functions, the administrator can click More > Edit in the Operation column on the Annotation Task page, determine whether to enable the AI-assisted annotation function, and set review requirements.
  • Delete: The administrator can click More > Delete in the Operation column on the Annotation Task page to delete the current annotation task.
