Updated on 2025-11-04 GMT+08:00
Setting Candidate Prompts
Set a prompt that yields favorable results as a candidate prompt and compare the outcomes of different candidate prompts.
A maximum of nine candidate prompts can be added for each prompt engineering project. If the number of candidate prompts reaches this maximum, delete previously selected prompts before you can add new ones.
  1. Log in to ModelArts Studio and access a workspace.
  2. In the navigation pane, choose Agent Dev. On the displayed page, choose Prompt Engineering > Prompt dev.
  3. In the prompt engineering project list, locate the desired project and click writing in the Operation column.
    Figure 1 Prompt Engineering
  4. In the Prompt area, click Set As Candidate in the upper left corner to set the current prompt as a candidate.
    The candidate prompts are saved under the candidate menu in the navigation pane.
    Figure 2 Set As Candidate
