Updated on 2025-11-04 GMT+08:00
Previewing Prompt Outcomes
Set values for prompt variables, feed the model with complete prompts, and observe the outcomes from different prompts.
  1. In the Variable Input area of the writing page, enter the variables in the text box.
    After variables are defined, the preview area will automatically show the complete prompt. You can also select an existing variable set and enter variable values. A variable set is an Excel file. Each row of data contains variable values to be entered. You can use the Import function to upload a variable set.
    Figure 1 Effect Preview
  2. Click View Results to view the model's answer. You can adjust the prompt text and variables based on the previewed outcome.
