Help Center/ PanguLargeModels/ User Guide/ Using Data Engineering to Create a Dataset/ Common Errors and Solutions for Data Engineering
Updated on 2025-07-02 GMT+08:00
Table 1 lists the common errors and solutions for data engineering.
Table 1 Common errors and solutions for data engineering
Function
Error
Solution
Data Acquisition
File format mismatch, require [{0}].
Check whether the data used for creating the dataset is in the format required by the platform.
Verification failed. Please check the content format is consistent with the template requirements.
content type [%s] not support, only [%s] support.
The content in the dataset is not supported. Ensure that the format of the uploaded data is the same as that required by the platform.
get obs bucket folders error.
Check whether the OBS service is normal and whether data in the OBS bucket can be accessed.
Data Processing
dataset is not online.
The dataset used for data processing has not been brought online. Bring the dataset online first.
invalid obs path.
Check whether the OBS path corresponding to the dataset is valid and can be accessed.
Data Labeling
annotate data not exist.
Check whether the labeled dataset exists and has been deleted.
obs url invalid.
data management query dataset data invalid.
dataset obs file empty.
Check whether the dataset file exists in the original OBS bucket.
download obs file failed.
Check whether the network is normal and whether data in the OBS bucket can be accessed.
Data Evaluation
annotate type is invalid.
Check whether the data labeling type and data labeling requirements in the uploaded data are consistent with those required by the platform.
The evaluation dataset does not exist. Check whether the dataset has been successfully imported and whether the OBS bucket is empty.
obs url invalid.
standard item not exist.
Check whether the evaluation criteria exist and have been deleted.
the corresponding data has been marked as deleted.
Check whether the evaluation dataset is deleted.
the current data not exist.
Check whether the evaluation dataset exists and has been deleted.
dataset file type does not match standard file type.
Check whether the type of the uploaded dataset file is the same as the standard file type required by the platform.
Check whether the dataset contains data in incorrect formats.
Data Publishing
Dataset [%s] is not found.
Check whether the dataset exists.
Dataset [%s] status is invalid.
Check whether the dataset status is normal.
