Updated on 2025-11-20 GMT+08:00
Operator Configuration File Specifications
Table 1 Basic information configuration specifications
Type
Mandatory
id
string
Yes
Operator name in English.
The operator name must start with a letter and can contain up to 128 characters, including letters, digits, and underscores (_). If the length exceeds 128 characters, the excess part is automatically truncated.
The ID cannot be changed when the operator is updated.
The ID of a visible operator in all workspaces is unique in all workspaces, and the ID of a visible operator in the current workspace is unique in the current workspace.
name
string
Yes
Operator display name.
The value contains a maximum of 128 characters. The excess part is automatically truncated.
description
string
No
Operator description.
The length cannot exceed 2000 characters. The excess part is automatically truncated.
author
string
No
Developer name.
version
string
Yes
Operator version.
The value contains a maximum of 32 characters. The excess part is automatically truncated. The format is as follows: number.number.number.
tags
tags object
Yes
Operator label, which is used for classification and filtering.
For details, see Table 2.
labels
Array of label objects
No
Label output by the labeling operator.
For details, see Table 7.
runtime
runtime object
Yes
Operator running configuration.
For details, see Table 3.
arguments
Array of argument objects
No
List of operator input parameters.
For details, see Table 5.
Table 2 Tag configuration specifications
Type
Mandatory
language
Array of strings
Yes
List of languages that can be processed by the operator, for example, zh and en.
The length of a single character string cannot exceed 32 characters. The excess part is automatically truncated.
Enter an international language code.
format
Array of strings
Yes
List of dataset file name extensions supported by the operator, for example, JSON, CSV, and MP4.
category
string
Yes
Operator type.
Select only one option. The options are as follows:
- Data extraction
- Data sampling
- Data conversion
- Data filtering
- Data deduplication
- Data labeling
- Other
modal
Array of strings
Yes
List of data modalities supported by the operator.
Select one or multiple options. The options are as follows:
- TEXT
- IMAGE
- VIDEO
- AUDIO
- OTHER (including weather and prediction)
custom
Array of strings
No
List of custom operator tags.
Table 3 runtime configuration specifications
Type
Mandatory
cpu-arch
Array of strings
Yes
List of CPU architectures supported by the operator.
- ARM
- X86
xpu-devices
Array of strings
No
List of device models supported by the operator. This parameter is mandatory when the operator runs on NPUs.
- SNT9B
This parameter is mandatory when the number of NPUs of a resource in runtime.resources is greater than 0. The value can be SNT9B.
environment
string
Yes
Operator package type. Only pure Python operator packages are supported.
- PYTHON
entrypoint
string
Yes
Operator startup command.
If environment is set to python, enter the fixed name process.py. The name cannot be changed.
auto-data-loading
boolean
Yes
Whether to automatically load data.
If the value is true, the framework processes the input and output. If the value is false, the user processes the input and output.
resources
Array of resource objects
No
List of resource sizes required for running a single operator instance.
This parameter is mandatory when environment is set to python.
Table 4 resource configuration specifications
Type
Mandatory
cpu
integer
Yes
Default CPU resources of a single instance (unit: vCPU).
You need to configure it based on the actual number of general computing units.
memory
integer
Yes
Default memory size of a single instance, in MB.
npu
integer
No
Default number of NPUs of a single instance, in card.
You need to set this parameter based on the specifications and quantity of the subscribed intelligent computing units.
Table 5 argument configuration specifications
Type
Mandatory
key
string
Yes
Parameter ID, which must be unique in the parameter list.
name
string
Yes
Parameter display name.
type
string
Yes
Parameter type.
- STRING
- FLOAT
- INT
- ENUM (radio button)
- LIST (check box)
- OBS (front-end component parameter for selecting an OBS file)
- BOOLEAN
tips
string
No
Parameter description.
min
float
No
Minimum value of the parameter. This parameter is optional when type is set to INT or FLOAT.
A maximum of four decimal places are reserved for floating-point numbers.
max
float
No
between
boolean
No
Whether the parameter is a range-type numeric parameter. This parameter is optional when type is set to INT or FLOAT. The default value is false.
items
Array of item objects
No
List of enumerated values. This parameter is mandatory when type is set to ENUM or LIST.
This parameter is mandatory when type is set to ENUM or LIST. The number of enumerated items must be at least 1.
required
boolean
No
Whether the parameter is mandatory.
Set it to true or false.
visible
boolean
No
Whether the parameter is visible to the frontend.
default
string
No
Default parameter value.
If visible is set to false and requires is set to true, the default value must be set.
If there are multiple default values, separate them with commas (,), for example, SD,HD.
The default value of a numeric parameter is in the format of min;max.
Table 6 item configuration specifications
Type
Mandatory
name
string
Yes
Enumerated item value.
value
string
Yes
Value of the enumerated item.
tips
string
No
Description or description of the enumerated item.
Table 7 label configuration specifications
Type
Mandatory
key
string
Yes
Key of a tag.
The key can contain a maximum of 128 characters. If the key exceeds 128 characters, the excess part is automatically truncated. The key must be unique among operators.
name
string
Yes
Tag name.
type
string
Yes
Tag type.
Enumerated value. The options are STRING, NUMERIC, ENUM, and OBJECT. Only one option can be selected.
min
float
No
Minimum tag value.
This parameter is mandatory when type is set to NUMERIC.
max
float
No
Maximum tag value.
items
Array of labelItem objects
No
Tag enumeration list.
This parameter is mandatory when type is set to ENUM.
dimensions
Array of labelDimension objects
No
Level-1 tag dimension.
This parameter is mandatory when type is set to OBJECT.
Table 8 labelItem configuration specifications
Type
Mandatory
name
string
Yes
Enumerated item name.
value
string
Yes
Enumerated value.
Table 9 labelDimension configuration specifications
Type
Mandatory
key
string
Yes
Key of the level-2 tag.
name
string
Yes
Level-2 tag name.
type
string
Yes
Level-2 tag type.
Enumerated value. The options are STRING, NUMERIC, and ENUM. Only one option can be selected.
min
float
No
Minimum value of the level-2 tag.
max
float
No
Maximum value of the level-2 tag.
items
No
Enumeration list of level-2 tags.
An operator configuration file is a YAML file that describes the basic information, function parameters, operating environment, and resource requirements of an operator. Configure the configuration file as follows:
id: video_clip    # (Mandatory) Operator abbreviation. The value must start with a letter and can contain a maximum of 128 characters, including letters, digits, and underscores (_). If the value contains more than 128 characters, the excess characters will be truncated.name: Video clip # (Mandatory) Operator display name. The value can contain a maximum of 128 characters. If the value contains more than 128 characters, the excess characters will be truncated.description: Splits a long video into multiple clips. # (Mandatory) Operator description. The value can contain a maximum of 2,000 characters.author: "xxx Technology Co., Ltd." # (Optional) Developer or team name, for example, Data Team. The value can contain a maximum of 128 characters.version: 1.0.0  #Rule "\\d+\\.\\d+\\.\\d+$"tags:  # (Mandatory) Operator tag, which is used for classification and filtering in specific scenarios. language: # (Mandatory) Language that can be processed by the operator. The value is a language code. Multiple options can be selected. Only international standard language codes are supported. The value contains a maximum of 32 characters.    - zh    - en    -...  format: # (Mandatory) Dataset file format supported by the operator. Multiple options are supported. The value contains a maximum of 32 characters.      - JSONL      - TXT      - CSV      - HTML      - MOBI      - EPUB      - DOCX      - PDF      - MP4      - AVI      -...  category: # (Mandatory) Operator type, which is used to display operators by category on the GUI. Only one option can be selected. The options are as follows:    - Data extraction    - Data sampling    - Data conversion    - Data filtering    - Data Deduplication    - Data labeling    - Other  modal:   # (Mandatory) Data modality supported by the operator. Multiple options can be selected. The options are as follows:    - TEXT    - IMAGE    - VIDEO    - AUDIO    - OTHER  custom: # Tag of a custom operator. Multiple options can be selected. The value contains a maximum of 32 characters.    - Data augmentation    - Pre-labeling    -...  task-categories:    - BACKFLOW # Backflowruntime:  cpu-arch:    - ARM  xpu-devices:    - SNT9B  # Operator resource configuration:  #   NPU operator configuration: 1 card, 24 cores, 192 GB  #   CPU operator configuration: 1 core 2 GB, 1 core 4 GB, 2 cores 4 GB, 4 cores 8 GB, 8 cores 16 GB  resources:    - cpu: 1      memory: 2048    - cpu: 24      memory: 196608 # Unit: MB      npu: 1  environment: python  entrypoint: process.py  auto-data-loading: true # Whether to automatically load data#All service parameters are input parameters of the operator. The data types of the parameters include STRING, FLOAT, INT, ENUM (radio button), LIST (check box), and OBS.arguments:  # Example of parameters of the STRING type  - key: filter_keywords # [Mandatory]    name: Filter keyword.    type: STRING    tips: The samples that match the keywords will be filtered. Multiple keywords are separated by commas (,).   #Tips on the GUI    required: true    visible: true    default: gambling  # Default value of the parameter. This parameter is optional. Use commas (,) to separate multiple default values.  # Example of the INT/FLOAT value range type  - key: length_of_characters # [Mandatory]    name: filtering duration range    type: FLOAT # [Mandatory] When type is set to int or float, the between field is mandatory.    between: true # Whether to obtain the value range. When type is set to int or float, the between field is mandatory.   min: 1.0   # Minimum value of the parameter, which is optional. When type is set to float, the value can contain a maximum of four decimal places. If the value exceeds the maximum, it will be truncated.    max: 500.0    # Range of the maximum parameter value. This field is optional.    tips: The filtering duration range includes the entered boundary value. The value is of the float type, in characters. Samples whose text length is within the specified range are retained. #GUI tips    required: true    visible: true    default: 100.0;300.0 # (Optional) Default maximum and minimum parameter values. If this parameter is not set, min;max is used as the default value.  # Example of parameters of the INT/FLOAT numeric type  - key: max_cropping_area_ratio    name: Maximum cropping area ratio    type: FLOAT    between: false # Whether the parameter is of the range type. The default value is false.    min: 0.0   # Range of the minimum value of the parameter    max: 100.0    # Range of the maximum value of the parameter    tips: The value is a float ranging from 0.0 to 100.0, in percentage (%). Samples whose cropped area ratio (cropped video area/original video area) is greater than the value will be filtered out.    visible: true    required: true     default: 100 # Default value  # Example of an ENUM parameter  - key: font_conversion    name: Text font conversion  type: ENUM  #Single choice    items:      - name: Simplified Chinese to Traditional Chinese        value: traditional      - name: Convert Traditional Chinese to Simplified Chinese        value: simplified    required: true    visible: true    default: simplified  # Example of a LIST parameter  - key: resolution    name: Resolution    type: LIST # Multiple options can be selected.    items: # Parameter options. This parameter is mandatory when type is set to ENUM or LIST.      - name: Smoothness   #[Mandatory]        value: SM   #[Mandatory]        tips: 480 > resolution ≥ 360        - name: SD        value: SD        tips: 720 > resolution ≥ 480      - name: HD        value: HD        tips: 1080 > resolution ≥ 720    required: true    visible: true          default: SD,HD # Use commas (,) to separate multiple default values.  # Example of an OBS parameter  - key: sensitive_word    name: OBS path of the sensitive word dictionary file    type: OBS    tips: sensitive word dictionary file    required: true    visible: true    default: NLP/system_resource/sensitive_word.csv # OBS path of the default word dictionary  # Example of a BOOLEAN parameter  - key: parse_all    name: Whether to parse all files    type: BOOLEAN    items:      - name: Yes        value: true      - name: No        value: false    visible: true    required: true    default: false
