Updated on 2025-07-02 GMT+08:00
Format Requirements for Weather Datasets
ModelArts Studio supports the import of weather datasets, including marine meteorological data.
Marine meteorological data is usually derived from weather reanalysis. Weather reanalysis uses modern weather models and data assimilation technologies to reprocess historical observation data and generate high-quality weather records. The data can be global or region-specific, aiming to provide complete, consistent, and high-resolution weather data.
The reanalysis data is in binary format. For details about the format requirements, see Table 1.
Table 1 Format requirements for weather datasets
File Content
File Format
Example
Meteorology - Weather data
nc, cdf, netcdf, gr, gr1, grb, grib, grb1, grib1, gr2, grb2, and grib2
  • Import from OBS: The size of a single file cannot exceed 50 GB, and the number of files is not limited.
Weather data usually includes global or regional weather variables, such as temperature (T), atmospheric pressure (P), and wind speed (U and V). In a file, these variables may be arranged by time, geographical range, and pressure level. The following is an example:
{"geo_range": {"lat": ["-90.0", "90.0"], "lon": ["0.0", "360.0"]}, "time_range": ["1640995200000", "1641164400000"], "total_size": 7376211808, "surface_features": ["P", "T", "U", "V"], "upper_air_layers": ["1000hPa", "100hPa", "150hPa", "175hPa", "200hPa", "250hPa", "300hPa", "400hPa", "500hPa", "50hPa", "600hPa", "700hPa", "850hPa", "925hPa"], "upper_air_features": ["Q", "T", "U", "V", "Z"]}
  • geo_range: defines the geographical range covered by data. The value of lat ranges from -90.0 to 90.0, and the value of lon ranges from 0.0 to 360.0.
  • time_range: time range of data. The timestamp is in milliseconds.
  • total_size: total size of the files to download, in bytes.
  • surface_features: list of surface variables, such as atmospheric pressure (P), temperature (T), and wind speed (U and V).
  • upper_air_layers: upper-air pressure levels, for example, 1000 hPa and 100 hPa.
  • upper_air_features: upper-air variables, for example, humidity (Q), temperature (T), wind speed (U and V), and height (Z).
Meteorology - Ocean data
  • Ocean data usually contains global or regional ocean variables, such as temperature (T), atmospheric pressure (P), and wind speed (U and V). The following is an example of the format:
    {"geo_range": {"lat": ["-90.0", "90.0"], "lon": ["0.0", "360.0"]}, "time_range": ["1640995200000", "1641164400000"], "total_size": 7376211808, "surface_features": ["SSH", "T", "P", "U", "V"], "under_sea_layers": ["0m", "6m", "10m", "20m", "30m", "50m", "70m", "100m", "125m", "150m", "200m", "250m", "300m", "400m", "500m"], "under_sea_features": [ "T", "U", "V", "S"]}
    • surface_features: list of sea surface variables, such as sea surface height (SSH), temperature (T), and wind speed (U and V).
    • under_sea_layers: deep-sea pressure levels, for example, 500 m and 400 mPa.
    • under_sea_features: list of deep-sea variables, such as sea salt (S), temperature (T), and sea flow rate (U and V).
Meteorology - Ecological data
Ecological data usually includes ecological variables such as total chlorophyll concentration (Tca), chlorophyll concentration (Chl), and diatom concentration (Dia). The following is an example:
{"geo_range": {"lat": ["-90.0", "90.0"], "lon": ["0.0", "360.0"]}, "time_range": ["1640995200000", "1641164400000"], "total_size": 7376211808, "surface_features": ["Tca","Chl","Dia","Coc","Cya","Irn","Nit","MLD"]}
  • surface_features: ecological variables, for example, Tca, Chl, and Dia.
Meteorology - Wave data
Wave data usually includes the significant wave height (SWH). The following is an example:
{"geo_range": {"lat": ["-90.0", "90.0"], "lon": ["0.0", "360.0"]}, "time_range": ["1640995200000", "1641164400000"], "total_size": 7376211808, "surface_features": ["SWH"]}
  • surface_features: wave variable, which is significant wave height (SWH).
