CodeArts Wiki
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by CodeArts Wiki, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by CodeArts Wiki, see Conditions.
The following table lists the actions that you can define in SCP statements for CodeArts Wiki.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
cloudwiki::access |
Permission to access CodeArts Wiki. |
write |
Each API of CodeArts Wiki usually supports one or more actions. Table 2 lists the supported actions and dependencies.
API |
Action |
Dependencies |
ApigDeleteFile |
cloudwiki::access |
ExternalDeleteFile |
cloudwiki::access |
DeleteVersionFromFile |
cloudwiki::access |
codeartsworkspace:project:getCreatorAccountActivationStatus |
DeleteFileInfoById |
cloudwiki::access |
BatchLogicDeleteFile |
cloudwiki::access |
DeleteFile |
cloudwiki::access |
ApigDownloadFile |
cloudwiki::access |
ExternalDownloadFile |
cloudwiki::access |
PreviewOrDownloadFile |
cloudwiki::access |
GetDownloadTaskList |
cloudwiki::access |
DownloadTaskById |
cloudwiki::access |
GetDownloadTaskById |
cloudwiki::access |
DownloadFiles |
cloudwiki::access |
DeleteDownloadTask |
cloudwiki::access |
MoveFile |
cloudwiki::access |
MoveFileFolder |
cloudwiki::access |
RenameFolder |
cloudwiki::access |
SortFile |
cloudwiki::access |
ExternalGetSubNodesByBelongId |
cloudwiki::access |
ExternalGetChildrenFile |
cloudwiki::access |
ExternalGetFileList |
cloudwiki::access |
ExternalGetMyFileList |
cloudwiki::access |
ExternalGetAmount |
cloudwiki::access |
ExternalGetPrjList |
cloudwiki::access |
ExternalGetFileInfoByDocId |
cloudwiki::access |
GetFileInfoById |
cloudwiki::access |
GetHotFilesPage |
cloudwiki::access |
GetFileHistoryList |
cloudwiki::access |
GetTreeByNodeId |
cloudwiki::access |
GetChildren |
cloudwiki::access |
SearchFiles |
cloudwiki::access |
GetMyCreateFiles |
cloudwiki::access |
GetDriverFileInfoById |
cloudwiki::access |
GetAssociationList |
cloudwiki::access |
codeartsreq:workitem:list,codeartsreq:workitem:get |
cloudwiki::access |
ExternalPreviewFile |
cloudwiki::access |
ExternalGetPreviewUrl |
cloudwiki::access |
GetFilePreViewInfo |
cloudwiki::access |
PreviewFile |
cloudwiki::access |
PreviewObsUrl |
cloudwiki::access |
ObsAuthorizeResource |
cloudwiki::access |
AddTenantInviteFromFile |
cloudwiki::access |
GetInviteListByObjIdFromFile |
cloudwiki::access |
GetShareDocHtmlFromFile |
cloudwiki::access |
AddInviteFromFile |
cloudwiki::access |
GetInviteListByTenantFromFile |
cloudwiki::access |
DeleteInviteFromFile |
cloudwiki::access |
PublicTreeFromFile |
cloudwiki::access |
ShareFile |
cloudwiki::access |
UpdateInvitePermission |
cloudwiki::access |
UpdateVersionNameFromFile |
cloudwiki::access |
RecoverVersionFromFile |
cloudwiki::access |
RenameFile |
cloudwiki::access |
UpdateFileParentPath |
cloudwiki::access |
SaveAssociations |
cloudwiki::access |
DeleteAssociations |
cloudwiki::access |
GetMyFavouriteFiles |
cloudwiki::access |
UploadConvertResult |
cloudwiki::access |
ApigUploadFile |
cloudwiki::access |
ExternalUploadFile |
cloudwiki::access |
ExternalPrjUpload |
cloudwiki::access |
FileStore |
cloudwiki::access |
Save |
cloudwiki::access |
BatchGetPreviewLink |
cloudwiki::access |
SaveUpload |
cloudwiki::access |
Upload |
cloudwiki::access |
ValidateFolder |
cloudwiki::access |
SaveFolder |
cloudwiki::access |
UploadFolder |
cloudwiki::access |
CreateFolder |
cloudwiki::access |
DeleteFileFolder |
cloudwiki::access |
DownloadFileFolder |
cloudwiki::access |
AddAttachment |
cloudwiki::access |
GetAttachments |
cloudwiki::access |
DeepCopyChildren |
cloudwiki::access |
CopyDocument |
cloudwiki::access |
CheckTemplatePermission |
cloudwiki::access |
SaveDoc |
cloudwiki::access |
CreateDocByDocSourceAndRedirectEditPage |
cloudwiki::access |
CreateDocAndRedirectEditPage |
cloudwiki::access |
UploadZipFile |
cloudwiki::access |
LogicDeleteDoc |
cloudwiki::access |
BatchLogicDeleteDoc |
cloudwiki::access |
ConvertAndExport |
cloudwiki::access |
JumpDolphinById |
cloudwiki::access |
BatchDownloadDoc |
cloudwiki::access |
ValidateImportDoc |
cloudwiki::access |
ResolveZipFile |
cloudwiki::access |
ImportDoc |
cloudwiki::access |
MoveDocument |
cloudwiki::access |
RenameDocFolder |
cloudwiki::access |
translateText |
cloudwiki::access |
codeartsreq:report:list,codeartsreq:report:get |
GetReportTree |
cloudwiki::access |
GetAllByTreeId |
cloudwiki::access |
GetVersionContentByContentId |
cloudwiki::access |
GetMyFavouriteDocs |
cloudwiki::access |
DoFavourites4Organization |
cloudwiki::access |
BatchDocFavourites |
cloudwiki::access |
GetDocListTitles |
cloudwiki::access |
GetRecentRecords |
cloudwiki::access |
GetRecentRecordDocs |
cloudwiki::access |
GetTreeByZhiShiKuId |
cloudwiki::access |
GetNodeCountByZhiShiKuId |
cloudwiki::access |
GetTreeAncestors |
cloudwiki::access |
GetSons |
cloudwiki::access |
GetBrothers |
cloudwiki::access |
GetTreeBaseInfo |
cloudwiki::access |
GetWidget |
cloudwiki::access |
GetContentHistoryList |
cloudwiki::access |
SearchDocs |
cloudwiki::access |
GetDocPermission |
cloudwiki::access |
GetMyCreateDocs |
cloudwiki::access |
GetLastCreateParent |
cloudwiki::access |
GetTopDocumentsPage |
cloudwiki::access |
GetDocListByProjectId |
cloudwiki::access |
GetMyCreateDocs4OldWiki |
cloudwiki::access |
RemoveRecentRecords |
cloudwiki::access |
SyncWikiInfo |
cloudwiki::access |
GetInviteListByTenantFromDoc |
cloudwiki::access |
GetShareDocHtmlFromDoc |
cloudwiki::access |
DeleteInviteFromDoc |
cloudwiki::access |
AddInviteFromDoc |
cloudwiki::access |
GetInviteListByObjIdFromDoc |
cloudwiki::access |
AddTenantInviteFromDoc |
cloudwiki::access |
AddZhishikuInviteFromDoc |
cloudwiki::access |
UpdateInvitePermissionFromDoc |
cloudwiki::access |
ShareFromDoc |
cloudwiki::access |
PublicTreeFromDoc |
cloudwiki::access |
GetReportData |
cloudwiki::access |
GetRelItemObjects |
cloudwiki::access |
GetRelItems |
cloudwiki::access |
GetEditorAuthToken |
cloudwiki::access |
DeleteWidgetById |
cloudwiki::access |
DeleteVersion |
cloudwiki::access |
DeleteDocItem |
cloudwiki::access |
DeleteTag |
cloudwiki::access |
CreateTag |
cloudwiki::access |
UpdateEditorContent |
cloudwiki::access |
UpdateWidget |
cloudwiki::access |
SaveWidget |
cloudwiki::access |
RecoverVersion |
cloudwiki::access |
UpdateVersionNameFromDoc |
cloudwiki::access |
GetDocJoinTag |
cloudwiki::access |
CreateDocJoinTag |
cloudwiki::access |
DeleteDocJoinByDocId |
cloudwiki::access |
RenameDoc |
cloudwiki::access |
ConvertText |
cloudwiki::access |
CreateTags |
cloudwiki::access |
SaveDocItem |
cloudwiki::access |
AtUser |
cloudwiki::access |
ApplayDocEditPermission |
cloudwiki::access |
DeleteAttachment |
cloudwiki::access |
CreateContent |
cloudwiki::access |
CopyDocFolder |
cloudwiki::access |
CreateDocFolder |
cloudwiki::access |
UpdateExtendAttribute |
cloudwiki::access |
DeleteDocFolder |
cloudwiki::access |
SortDoc |
cloudwiki::access |
GetTags |
cloudwiki::access |
MoveDocFolder |
cloudwiki::access |
CopyMailTemplate |
cloudwiki::access |
SaveMailTemplate |
cloudwiki::access |
GetMailTemplateList |
cloudwiki::access |
GetMailTemplatePage |
cloudwiki::access |
GetSendMailPage |
cloudwiki::access |
UpdateMailTemplate |
cloudwiki::access |
SendMailTemplate |
cloudwiki::access |
DeleteMailTemplate |
cloudwiki::access |
DeleteDomainAdmin |
cloudwiki::access |
DeletePrivateMember |
cloudwiki::access |
DeleteMember |
cloudwiki::access |
GetDomainAdmins |
cloudwiki::access |
GetUserInviteListByTenant |
cloudwiki::access |
GetUsersByTenant4Search |
cloudwiki::access |
IsCurrentUserOrgAdmin |
cloudwiki::access |
GetAllMemberByOrgIdPage |
cloudwiki::access |
GetAllAdminsByOrgId |
cloudwiki::access |
SaveMembers |
cloudwiki::access |
SavePrivateMembers |
cloudwiki::access |
SaveFilePrivateMembers |
cloudwiki::access |
SaveDomainAdmin |
cloudwiki::access |
BatchDeleteOrganization |
cloudwiki::access |
LogicDeleteOrg |
cloudwiki::access |
GetMyFavouriteOrganizations |
cloudwiki::access |
DoFavourites4Wiki |
cloudwiki::access |
GetTreeByOrgId |
cloudwiki::access |
GetAllByOrgId |
cloudwiki::access |
VerifyId |
cloudwiki::access |
GetAllOrganization |
cloudwiki::access |
GetOrgId |
cloudwiki::access |
BatchUpdateOrgByIds |
cloudwiki::access |
BatchRecoverOrg |
cloudwiki::access |
SaveOrganization |
cloudwiki::access |
DeleteGlobalRecycleObjects |
cloudwiki::access |
DeleteFiles |
cloudwiki::access |
DeleteDoc |
cloudwiki::access |
CleanRecycle |
cloudwiki::access |
BatchDeleteTeamZskOrDrive |
cloudwiki::access |
CleanCloudDriveRecycle |
cloudwiki::access |
GetRecycleListByPage |
cloudwiki::access |
GetGlobalRecycleListByPage |
cloudwiki::access |
GetGlobalRecycleDeleters |
cloudwiki::access |
GetGlobalRecycleCreators |
cloudwiki::access |
GetRecyclePage |
cloudwiki::access |
RecoverDoc |
cloudwiki::access |
BatchRecoverZskOrDrive |
cloudwiki::access |
RecoverGlobalRecycleObject |
cloudwiki::access |
Recover |
cloudwiki::access |
CreateRole |
cloudwiki::access |
DeleteRole |
cloudwiki::access |
GetRoleList |
cloudwiki::access |
UpdateRole |
cloudwiki::access |
UpdateMemberRole |
cloudwiki::access |
SavePrivateZhiShiKu |
cloudwiki::access |
CreateTeamZskOrDrive |
cloudwiki::access |
SavePrivateDrive |
cloudwiki::access |
LogicDeletePrivateZhiShiKu |
cloudwiki::access |
BatchLogicDeleteZskOrDrive |
cloudwiki::access |
LogicDeletePrivateDrive |
cloudwiki::access |
UpdateMigrateAllStatus |
cloudwiki::access |
ChangeWorkNO |
cloudwiki::access |
GetPrivateDriveById |
cloudwiki::access |
DoFavourites |
cloudwiki::access |
AddOrCancelThumbs |
cloudwiki::access |
GetZskOrDrivePage |
cloudwiki::access |
MigrateSingle |
cloudwiki::access |
DeleteSingle |
cloudwiki::access |
MigrateIncrement |
cloudwiki::access |
MigrateFile |
cloudwiki::access |
GlobalBatchCancelFavourites |
cloudwiki::access |
BatchFileFavourites |
cloudwiki::access |
GetZhiShiKuById |
cloudwiki::access |
GetProjectZhiShiKu |
cloudwiki::access |
GetZhiShiKuList |
cloudwiki::access |
GetGlobalProjectList |
cloudwiki::access |
GetGlobalZhiShiKuList |
cloudwiki::access |
MigrateProjectById |
cloudwiki::access |
InitProjectMigration |
cloudwiki::access |
InitDomainMigration |
cloudwiki::access |
GetThumbsByObjId |
cloudwiki::access |
CheckTenantNameExists |
cloudwiki::access |
CheckTenantNameAndUserNameExists |
cloudwiki::access |
GetTeamsByPage |
cloudwiki::access |
GetZskDriveStatisticsByOrgId |
cloudwiki::access |
GetTeamRecentRecords |
cloudwiki::access |
GetZskDriveMemberQuantityByOrgId |
cloudwiki::access |
GetMyFavouritesInTeam |
cloudwiki::access |
GetMeAndDescendantsPage |
cloudwiki::access |
FullTextSearch |
cloudwiki::access |
GetUsersByTenant |
cloudwiki::access |
SuggestSearch |
cloudwiki::access |
SearchHistory |
cloudwiki::access |
DeleteHistory |
cloudwiki::access |
GetEspaceGroupList |
cloudwiki::access |
GetEspaceGroupUserList |
cloudwiki::access |
GetPrivilegeList |
cloudwiki::access |
GetModuleList |
cloudwiki::access |
QueryMigrateStatus |
cloudwiki::access |
GetGlobalFavourites |
cloudwiki::access |
GetGlobalFavouriteCreators |
cloudwiki::access |
GetDiscoveryPage |
cloudwiki::access |
GetConfigByKey |
cloudwiki::access |
GetConfigsByType |
cloudwiki::access |
GuideRedirect |
cloudwiki::access |
GetProjectDrive |
cloudwiki::access |
GetDrivePage |
cloudwiki::access |
GetZhiShiKuAmountInfo |
cloudwiki::access |
GetUserAmountInfo |
cloudwiki::access |
GetUpdateAmount |
cloudwiki::access |
GetProjectAmount |
cloudwiki::access |
GetNewAmountInfo |
cloudwiki::access |
CleanHistory |
cloudwiki::access |
RollBack |
cloudwiki::access |
SyncZhishiku |
cloudwiki::access |
ShareZhiShiKu |
cloudwiki::access |
PublicTreeFromWiki |
cloudwiki::access |
UpdateZhishikuInvitePermission |
cloudwiki::access |
PublicPrivateTree |
cloudwiki::access |
ShareZhiShiKu4Driver |
cloudwiki::access |
PublicTreeFromDriver |
cloudwiki::access |
UpdateZhishikuInvitePermission4Driver |
cloudwiki::access |
PublicPrivateTree4Driver |
cloudwiki::access |
AddTenantZhishikuInvite |
cloudwiki::access |
GetZhishikuInviteListByObjId |
cloudwiki::access |
AddZhishikuInvite4Driver |
cloudwiki::access |
AddZhishikuInvite |
cloudwiki::access |
AddTenantZhishikuInvite4Driver |
cloudwiki::access |
GetZhishikuInviteListByObjId4Driver |
cloudwiki::access |
AddZhishikuInvite4Wiki |
cloudwiki::access |
GetZhishikuInviteListByTenant |
cloudwiki::access |
GetShareTree |
cloudwiki::access |
PreviewSharedFileObsUrl |
cloudwiki::access |
GetZhishikuInviteListByTenant4Driver |
cloudwiki::access |
GetShareTree4Driver |
cloudwiki::access |
DeleteZhishikuInvite |
cloudwiki::access |
DeleteZhishikuInvite4Driver |
cloudwiki::access |
UpdateTeamZhiShiKu |
cloudwiki::access |
UpdateTeamZskExtendAttribute |
cloudwiki::access |
UpdatePrivateZhiShiKu |
cloudwiki::access |
UpdatePriviteZskExtendAttribute |
cloudwiki::access |
UpdateTeamDrive |
cloudwiki::access |
UpdatePrivateDrive |
cloudwiki::access |
UpdateProjectSpaceSettings |
cloudwiki::access |
SaveTalkNotes |
cloudwiki::access |
GetTalkNotesPage |
cloudwiki::access |
GetTalkNotesTimes |
cloudwiki::access |
SyncWikiTalknotes |
cloudwiki::access |
DeleteTalkNotes |
cloudwiki::access |
SaveTemplate |
cloudwiki::access |
SaveDocToTemplate |
cloudwiki::access |
DeleteTemplate |
cloudwiki::access |
GetTemplatePage |
cloudwiki::access |
GetTemplateById |
cloudwiki::access |
GetTemplateThumbnail |
cloudwiki::access |
GetTemplateList |
cloudwiki::access |
QueryTemplateCategory |
cloudwiki::access |
SyncTemplate |
cloudwiki::access |
RenameTemplate |
cloudwiki::access |
ExchangeTemplate |
cloudwiki::access |
ChangeTemplateCategory |
cloudwiki::access |
UpdateTemplateCategory |
cloudwiki::access |
UploadPreViewImg |
cloudwiki::access |
SaveTemplateCategory |
cloudwiki::access |
DeleteTemplateCategory |
cloudwiki::access |
