The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by CodeArts PerfTest, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by CodeArts PerfTest, see Conditions.
The following table lists the actions that you can define in SCP statements for CodeArts PerfTest.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
codeartsperftest:privateResourceGroup:update |
Grants permission to modify a private resource group. |
write |
privateResourceGroup |
codeartsperftest:privateResourceGroup:list |
Grants permission to view the private resource group list. |
list |
codeartsperftest:privateResourceGroup:get |
Grants permission to view a private resource group. |
read |
codeartsperftest:privateResourceGroup:delete |
Grants permission to delete a private resource group. |
write |
codeartsperftest:privateResourceGroup:create |
Grants permission to create a private resource group. |
write |
codeartsperftest:jmeter:updateJmeterTask |
Grants permission to modify a JMeter task. |
write |
jmeter |
codeartsperftest:jmeter:updateJmeterProject |
Grants permission to modify a JMeter project. |
write |
jmeter |
codeartsperftest:jmeter:listJmeterTask |
Grants permission to view the JMeter task list. |
list |
jmeter |
codeartsperftest:jmeter:listJmeterProject |
Grants permission to view the JMeter project list. |
list |
jmeter |
codeartsperftest:jmeter:getJmeterTask |
Grants permission to view a JMeter task. |
read |
jmeter |
codeartsperftest:jmeter:getJmeterProject |
Grants permission to view a JMeter project. |
get |
jmeter |
codeartsperftest:jmeter:executeJmeterTask |
Grants permission to execute or stop a JMeter task. |
write |
jmeter |
codeartsperftest:jmeter:deleteJmeterTask |
Grants permission to delete a JMeter task. |
write |
jmeter |
codeartsperftest:jmeter:deleteJmeterProject |
Grants permission to delete a JMeter project. |
write |
jmeter |
codeartsperftest:jmeter:createJmeterTask |
Grants permission to create a JMeter task. |
write |
jmeter |
codeartsperftest:jmeter:createJmeterResource |
Grants permission to create a JMeter resource, such as JMeter variable or JAR package. |
write |
jmeter |
codeartsperftest:jmeter:createJmeterProject |
Grants permission to create a JMeter project. |
write |
jmeter |
codeartsperftest:cpts:updatePerfTestTask |
Grants permission to modify a PerfTest task. |
write |
cpts |
codeartsperftest:cpts:updatePerfTestProject |
Grants permission to modify a PerfTest project, case, and directory. |
write |
cpts |
codeartsperftest:cpts:listPerfTestTask |
Grants permission to view the PerfTest task list. |
list |
cpts |
codeartsperftest:cpts:listPerfTestProject |
Grants permission to view the PerfTest project list. |
list |
cpts |
codeartsperftest:cpts:getPerfTestTask |
Grants permission to view a PerfTest task. |
read |
cpts |
codeartsperftest:cpts:getPerfTestProject |
Grants permission to view a PerfTest project. |
read |
cpts |
codeartsperftest:cpts:executePerfTestTask |
Grants permission to execute or stop a PerfTest task. |
write |
cpts |
codeartsperftest:cpts:deletePerfTestTask |
Grants permission to delete a PerfTest task. |
write |
cpts |
codeartsperftest:cpts:deletePerfTestProject |
Grants permission to delete a PerfTest project, case, and directory. |
write |
cpts |
codeartsperftest:cpts:createPerfTestTask |
Grants permission to create a PerfTest task. |
write |
cpts |
codeartsperftest:cpts:createPerfTestResource |
Grants permissions to create a PerfTest resource, such as PerfTest case, directory, and variable. |
write |
cpts |
codeartsperftest:cpts:createPerfTestProject |
Grants permission to create a PerfTest project. |
write |
cpts |
codeartsperftest::uploadFile |
Grants permission to upload a file. |
write |
codeartsperftest::updateSlaTemplate |
Grants permission to update an SLA template. |
write |
codeartsperftest::updateCronTask |
Grants permission to modify a crontask. |
write |
codeartsperftest::orderPackage |
Grants permission to buy a package. |
write |
codeartsperftest::listTag |
Grants permission to view the tag list. |
list |
codeartsperftest::listSlaTemplate |
Grants permission to view the SLA template list. |
list |
codeartsperftest::listPackage |
Grants permission to view the purchased packages. |
list |
codeartsperftest::listCronTask |
Grants permission to view the crontask list. |
list |
codeartsperftest::getTag |
Grants permission to view a project's tags. |
read |
codeartsperftest::getSlaTemplate |
Grants permission to view an SLA template. |
read |
codeartsperftest::getCronTask |
Grants permission to view a crontask. |
read |
codeartsperftest::deleteTag |
Grants permission to delete a project's tags. |
tagging |
codeartsperftest::deleteSlaTemplate |
Grants permission to delete an SLA template. |
write |
codeartsperftest::deleteCronTask |
Grants permission to delete a crontask. |
write |
codeartsperftest::createTag |
Grants permission to create tags for a project. |
tagging |
codeartsperftest::createSlaTemplate |
Grants permission to create an SLA template. |
write |
codeartsperftest::createCronTask |
Grants permission to create a crontask. |
write |
Each API of CodeArts PerfTest usually supports one or more actions. Table 2 lists the supported actions and dependencies.
API |
Action |
Dependencies |
POST /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/monitors |
GET /v1/{project_id}/jmeter/test-suites |
POST /v1/{project_id}/jmeter/test-suites |
POST /v2/{project_id}/stress/apps |
POST /v1/{project_id}/periodic_package |
PUT /v2/{project_id}/stress/apps/batch |
PUT /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/fields |
GET /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/tasks/{task_run_info_id}/transactions/{transaction_id} |
POST /v1/{project_id}/stress/agents/plugin-packages/init-multipart |
GET /v1/{project_id}/all-plugin-func/{test_suite_id} |
PUT /v2/{project_id}/stress/agents/batch-delete |
GET /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/file-variables |
GET /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/tasks/{task_run_info_id}/transactions/{transaction_id}/index/{index}/css-log |
POST /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/batch-update-status |
GET /v2/{project_id}/stress/apps/{id} |
GET /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/tasks/{task_run_info_id}/event |
GET /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/third-jar-packages |
GET /v1/{project_id}/jmeter/test-suites/{jmeter_project_id} |
DELETE /v2/{project_id}/stress/apps/{id} |
POST /v1/{project_id}/templates/file-upload/{template_id} |
GET /v2/{project_id}/stress/apps |
DELETE /v1/{project_id}/jmeter/test-suites/{jmeter_project_id} |
GET /v1/{project_id}/all-plugin-list/{test_suite_id} |
PUT /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id} |
GET /v1/{project_id}/all-plugin-req/{test_suite_id} |
GET /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/file-variables/{file_variable_id}/export |
DELETE /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/third-jar-packages/{third_jar_id} |
PUT /v1/{project_id}/monitors/{monitor_id} |
DELETE /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id} |
GET /v1/{project_id}/order-package |
PUT /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/monitors/{jmeter_monitor_id} |
POST /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans |
POST /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/debug |
DELETE /v1/{project_id}/templates/file-delete/{template_id} |
GET /v2/{project_id}/stress/apps/apm/business |
POST /v2/{project_id}/stress/apps/batch-delete |
PUT /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/thread-groups |
GET /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/third-jar-packages/{third_jar_id}/export |
GET /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/tasks/{task_run_info_id}/reports/log-outline |
POST /v2/{project_id}/stress/apps/apm/app-info/batch-get |
GET /v1/{project_id}/stress/agents/plugin-packages |
POST /v1/{project_id}/plugin-json-upload/test-suites/{test_suite_id} |
GET /v1/{project_id}/test-suites/{test_suite_id}/tasks/{task_id}/link-apps |
GET /v1/{project_id}/variable-file-download/variables/{variable_id} |
POST /v1/{project_id}/cce-agencies |
POST /v1/{project_id}/saveuser |
DELETE /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/monitors/{jmeter_monitor_id} |
POST /v1/{project_id}/test-suites/jmeter-upload |
POST /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/third-jar-packages/init-multipart |
POST /v1/{project_id}/cpts-agencies |
POST /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/file-variables |
PUT /v1/{project_id}/jmeter/test-suites/{jmeter_project_id} |
POST /v1/{project_id}/monitors |
POST /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/monitors |
GET /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/export |
GET /v1/{project_id}/all-plugin-check/{test_suite_id} |
POST /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/tasks |
POST /v1/{project_id}/variable-file-upload/test-suites/{test_suite_id} |
GET /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/monitors |
GET /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans |
POST /v1/{project_id}/templates/clone/{test_suite_id} |
PUT /v2/{project_id}/stress/apps/{id} |
PUT /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/file-variables |
PUT /v1/{project_id}/variable-file-upload/test-suites/{test_suite_id} |
POST /v3/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/debug |
DELETE /v2/{project_id}/stress/agents/{id} |
POST /v1/{project_id}/stress/agents/plugin-packages/upload |
DELETE /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/file-variables/{file_variable_id} |
POST /v1/{project_id}/stress/agents |
PUT /v1/{project_id}/stress/agents/{agent_id} |
GET /v1/{project_id}/task-run-infos/{task_run_id}/case-run-infos/{case_run_id}/csv |
DELETE /v1/{project_id}/prg/{prg_id}/file/{prg_file_id} |
GET /v1/{project_id}/search/{name} |
PUT /v2/{project_id}/test-cases/{case_id}/sla/{sla_id} |
GET /v1/{project_id}/tasksinfos |
GET /v2/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/tasks/{task_run_info_id}/case-run-infos/{case_run_id}/detail/{detail_id}/chart |
GET /v1/{project_id}/services/ondemand_order |
GET /v1/{project_id}/task-run-infos/{task_run_id}/sla/statistic |
GET /v1/{project_id}/{resource_type}/{resource_id}/tags |
DELETE /v3/{project_id}/tasks/{task_id} |
POST /v1/{project_id}/services/ondemand_order |
GET /v1/{project_id}/clusters/{cluster_id} |
GET /v2/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/tasks/{task_run_info_id}/case-run-infos/{case_run_id}/detail |
POST /v1/{project_id}/templates |
DELETE /v1/{project_id}/tasks/{task_id} |
PUT /v1/{project_id}/task-cases/{case_id}/target/{target} |
GET /v1/{project_id}/test-suites/count |
codeartsperftest:cpts:listPerfTestProjectcodeartsperftest:jmeter:listJmeterProject (determine which parameter is used based on the code) |
GET /v2/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/tasks/{task_run_info_id}/cases |
PUT /v2/{project_id}/debug/tasks/{id}/stop |
GET /v1/{project_id}/test-suites/{test_suite_id} |
PUT /v1/{project_id}/prgs/{prg_id} |
GET /v1/{project_id}/packages |
POST /v2/{project_id}/debug/tasks/batch-get |
GET /v1/{project_id}/{resource_type}/tags |
DELETE /v1/{project_id}/test-suites/{test_suite_id} |
PUT /v1/{project_id}/prgs/{prg_id}/ext |
POST /v1/{project_id}/{resource_type}/{resource_id}/tags/create |
GET /v1/{project_id}/task-run-infos/{task_run_id}/case-run-infos/{case_run_id}/stages |
GET /v2/{project_id}/jmeter/test-suites/{jmeter_project_id}/monitors |
GET /v1/{project_id}/slas |
GET /v1/{project_id}/test-suites/upload/processes |
PUT /v1/{project_id}/templates/{template_id} |
GET /v2/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/tasks/{task_run_info_id}/reports/details |
PUT /v1/{project_id}/test-suites/{test_suite_id} |
GET /v2/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/tasks/{task_run_info_id}/reports/log-outline |
GET /v1/{project_id}/monitors-by-task/{task_id} |
DELETE /v1/{project_id}/{resource_type}/{resource_id}/tags/delete |
POST /v1/{project_id}/domain-bindings-all/{test_suite_id} |
GET /v1/{project_id}/cron-task/execute-time |
GET /v1/{project_id}/resources/nodes/scaling/{prg_id} |
GET /v2/{project_id}/task-run-infos/{task_run_id}/reports/details |
GET /v1/{project_id}/monitors-by-run-id/{run_id} |
PUT /v1/{project_id}/sla/{sla_id} |
GET /v1/{project_id}/templates/{template_id} |
POST /v1/{project_id}/test-suites |
DELETE /v1/{project_id}/task-cases/{case_id} |
DELETE /v2/{project_id}/debug/tasks/{id} |
GET /v2/{project_id}/test-cases/{case_id} |
GET /v1/{project_id}/variables/{test_suite_id} |
DELETE /v2/{project_id}/test-cases/{case_id} |
POST /v2/{project_id}/test-cases/{case_id}/sla |
POST /v3/{project_id}/tasks |
PUT /v1/{project_id}/test-suites/{test_suite_id}/directory/{directory_id} |
GET /v1/{project_id}/agencies/all |
GET /v1/{project_id}/tasks/history-run-list/{task_id} |
GET /v2/{project_id}/task-run-infos/{task_run_id}/details/export |
GET /v2/{project_id}/task-run-infos/{task_run_id}/case-run-infos/{case_run_id}/detail |
POST /v1/{project_id}/templates/swagger-import/{test_suite_id}/contract-id/{contract_id}/model-id/{model_id} |
PUT /v1/{project_id}/variables/{test_suite_id} |
POST /v1/{project_id}/test-suites/{test_suit_id}/tasks/batch-update-task-status |
GET /v1/{project_id}/variables/{variable_type}/test-suites/{test_suite_id} |
GET /v1/{project_id}/cron-task |
POST /v1/{project_id}/tasks |
GET /v1/{project_id}/test-suites |
POST /v1/{project_id}/prg/{prg_id}/upload |
POST /v1/{project_id}/{resource_type}/resource-instances/count |
POST /v1/{project_id}/test-suites/download |
GET /v1/{project_id}/all-tasks/{test_suite_id} |
GET /v1/{project_id}/tasks/{task_id} |
PUT /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/multi-third-jar-packages/{third_jar_id} |
GET /v1/{project_id}/cron-task/{cron_task_id} |
POST /v1/{project_id}/prgs |
GET /v2/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/tasks/{task_run_info_id}/details/export |
GET /v1/{project_id}/monitor-list/{test_suite_id} |
GET /v1/{project_id}/invite-features |
GET /v1/{project_id}/prgs/{prg_id} |
POST /v1/{project_id}/packages |
DELETE /v1/{project_id}/prgs/{prg_id}/ext/{ext_id} |
GET /v1/{project_id}/tasks/history-run-info/{run_id} |
DELETE /v1/{project_id}/cron-task/{cron_task_id} |
GET /v1/{project_id}/test-suites/{test_suite_id}/directory |
GET /v1/{project_id}/task-run-infos/{task_run_id}/event/sla |
POST /v2/{project_id}/test-cases/batch-delete |
PUT /v1/{project_id}/monitors-by-task/{task_id} |
GET /v1/{project_id}/pods-info/{exec_info_id} |
GET /v1/{project_id}/clusters |
GET /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id} |
GET /v1/{project_id}/task-run-infos/{task_run_id}/case-run-infos/{case_run_id}/reports |
GET /v1/{project_id}/task-run-infos/{task_run_id}/case-run-infos/{case_run_id}/index/{index}/debug-result |
PUT /v3/{project_id}/tasks/{task_id} |
DELETE /v2/{project_id}/test-cases/{case_id}/sla/{sla_id} |
POST /v1/{project_id}/templates/swagger-insert/{test_suite_id} |
DELETE /v1/{project_id}/prgs/{prg_id}/delete_forced |
GET /v2/{project_id}/test-cases/{case_id}/slas |
PUT /v1/{project_id}/test-suites/{test_suite_id}/domain-binding/{domain_binding_id} |
POST /v1/{project_id}/test-suites/{test_suite_id}/tasks/{task_id} |
GET /v1/{project_id}/task-run-infos/{task_run_id}/case-run-infos/{case_run_id}/index/{index}/css-log |
POST /v2/{project_id}/test-suites/{test_suite_id}/cases/{case_id}/debug |
POST /v1/{project_id}/cron-task |
POST /v1/{project_id}/templates/upload/{template_id} |
GET /v1/{project_id}/task-run-infos/{task_run_id}/case-run-infos/{case_run_id}/icon-metrics |
GET /v2/{project_id}/debug/tasks |
GET /v2/{project_id}/task-run-infos/{task_run_id}/cases |
GET /v1/{project_id}/task-run-infos/{task_run_id}/case-run-infos/{case_run_id}/event |
PUT /v1/{project_id}/cron-task/{cron_task_id} |
GET /v2/{project_id}/monitor-list/{test_suite_id} |
GET /v1/{project_id}/test-suites/{test_suit_id}/tasks/{task_id}/test-cases |
DELETE /v1/{project_id}/test-suites/{test_suite_id}/directory/{directory_id} |
POST /v1/{project_id}/prgs/{prg_id}/ext |
GET /v2/{project_id}/tasks/{task_id} |
PUT /v1/{project_id}/domain-bindings-all/{test_suite_id} |
POST /v1/{project_id}/sla |
GET /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/variables |
POST /v1/{project_id}/{resource_type}/resource-instances/filter |
POST /v1/{project_id}/test-suites/{test_suite_id}/directory |
PUT /v1/{project_id}/cron-task/{cron_task_id}/status |
GET /v1/{project_id}/prgs |
GET /v2/{project_id}/task-run-infos/{task_run_id}/reports/log-outline |
DELETE /v1/{project_id}/sla/{sla_id} |
PUT /v1/{project_id}/tasks/{task_id} |
GET /v1/{project_id}/sla/{sla_id} |
DELETE /v1/{project_id}/prgs/{prg_id} |
GET /v1/{project_id}/domain-bindings-all/{test_suite_id} |
POST /v3/{project_id}/test-suites/{test_suite_id}/cases/{case_id}/debug |
POST /v1/{project_id}/variable-file-upload/init-multipart |
POST /v1/{project_id}/templates/swagger-upload/{test_suite_id} |
GET /v2/{project_id}/test-cases/{case_id}/rel-temp-tasks |
POST /v2/{project_id}/test-cases |
PUT /v1/{project_id}/task-run-infos/{task_run_id}/case-run-infos/{case_run_id}/stages |
PUT /v2/{project_id}/test-cases/{case_id} |
POST /v2/{project_id}/test-cases/batch-run |
POST /v1/{project_id}/task-cases |
GET /v1/{project_id}/prg/{prg_id}/files |
GET /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/history-tasks |
GET /v1/{project_id}/all-templates/{test_suite_id} |
GET /v1/{project_id}/prg/regions |
GET /v2/{project_id}/task-run-infos/{task_run_id}/case-run-infos/{case_run_id}/detail/{detail_id}/chart |
POST /v1/{project_id}/test-suites/{test_suite_id}/tasks/{task_id}/cases/{case_id}/debug |
DELETE /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/multi-third-jar-packages |
POST /v1/{project_id}/domain-binding/{domain_binding_id} |
DELETE /v1/{project_id}/test-suites/upload |
codeartsperftest:cpts:createPerfTestProject&&codeartsperftest:cpts:createPerfTestResource |
DELETE /v1/{project_id}/prgs/{prg_id}/ratio |
DELETE /v1/{project_id}/templates/{template_id} |
GET /v1/{project_id}/variables |
POST /v1/{project_id}/prg/upload/{upload_id}/processes |
POST /v1/{project_id}/test-suites/{test_suit_id}/tasks/{task_id}/cron-tasks |
POST /v1/{project_id}/column/check-name |
GET /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/cron-tasks |
PUT /v1/{project_id}/jmeter/test-suites/{jmeter_project_id}/test-plans/{test_plan_id}/tasks/{task_run_info_id}/update-report-name |
PUT /v1/{project_id}/task-run-infos/{task_run_id}/update-report-name |
POST /v1/test-suites/upload-java/json-file |
codeartsperftest:cpts:createPerfTestProject codeartsperftest:cpts:createPerfTestResource |
POST /v1/test-suites/upload-java/init-multipart |
POST /v1/test-suites/upload-java/test-suites/{test_suite_id} |
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for CodeArts PerfTest.
Resource Type |
URN |
cpts |
codeartsperftest:<region>:<account-id>:cpts:<test-suite-name> |
jmeter |
codeartsperftest:<region>:<account-id>:jmeter:<test-suite-name> |
codeartsperftest:<region>:<account-id>:privateResourceGroup:<resource-group-name> |
Conditions
CodeArts PerfTest does not support service-specific condition keys in SCPs.
It can only use global condition keys applicable to all services. For details, see Global Condition Keys.
