IAM Identity Broker
Organizations also provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by IAM Identity Broker, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by IAM Identity Broker, see Conditions.
The following table lists the actions that you can define in policy statements for IAM Identity Broker.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
AgenciesAnywhere:trustAnchor:create |
Grants permission to create a trust anchor. |
Write |
AgenciesAnywhere:trustAnchor:enable |
Grants permission to enable a trust anchor. |
Write |
trustAnchor * |
AgenciesAnywhere:trustAnchor:disable |
Grants permission to disable a trust anchor. |
Write |
trustAnchor * |
AgenciesAnywhere:trustAnchor:update |
Grants permission to modify a trust anchor. |
Write |
trustAnchor * |
AgenciesAnywhere:trustAnchor:get |
Grants permission to query details about a trust anchor. |
Read |
trustAnchor * |
AgenciesAnywhere:trustAnchor:list |
Grants permission to list trust anchors. |
List |
AgenciesAnywhere:trustAnchor:delete |
Grants permission to delete a trust anchor. |
Write |
trustAnchor * |
AgenciesAnywhere:trustAnchor:putNotificationSettings |
Grants permission to set notification settings for a trust anchor. |
Write |
trustAnchor * |
AgenciesAnywhere:trustAnchor:resetNotificationSettings |
Grants permission to reset the notification settings for a trust anchor. |
Write |
trustAnchor * |
AgenciesAnywhere:profile:create |
Grants permission to create a profile. |
Write |
AgenciesAnywhere:profile:enable |
Grants permission to enable a profile. |
Write |
profile * |
AgenciesAnywhere:profile:disable |
Grants permission to disable a profile. |
Write |
profile * |
AgenciesAnywhere:profile:update |
Grants permission to modify a profile. |
Write |
profile * |
AgenciesAnywhere:profile:get |
Grants permission to query profile details. |
Read |
profile * |
AgenciesAnywhere:profile:list |
Grants permission to list profiles. |
List |
AgenciesAnywhere:profile:delete |
Grants permission to delete a profile. |
Write |
profile * |
AgenciesAnywhere::listResourcesByTag |
Grants permission to list resources or the resource quantity by tag. |
List |
AgenciesAnywhere::tagResource |
Grants permission to tag a specified resource. |
Tagging |
trustAnchor |
profile |
crl |
AgenciesAnywhere::unTagResource |
Grants permission to untag a specified resource. |
Tagging |
trustAnchor |
profile |
crl |
AgenciesAnywhere::listTagsForResource |
Grants permission to list the tags of a specified resource. |
List |
profile |
crl |
trustAnchor |
AgenciesAnywhere::listTags |
Grants permission to list resource tags. |
List |
AgenciesAnywhere:crl:import |
Grants permission to import a certificate revocation list. |
Write |
AgenciesAnywhere:crl:enable |
Grants permission to enable a certificate revocation list. |
Write |
crl * |
AgenciesAnywhere:crl:disable |
Grants permission to disable a certificate revocation list. |
Write |
crl * |
AgenciesAnywhere:crl:update |
Grants permission to update a certificate revocation list. |
Write |
crl * |
AgenciesAnywhere:crl:get |
Grants permission to query a certificate revocation list. |
Read |
crl * |
AgenciesAnywhere:crl:list |
Grants permission to list the certificate revocation lists. |
List |
AgenciesAnywhere:crl:listForTrustAnchor |
Grants permission to list the certificate revocation lists of a specified trust anchor. |
List |
trustAnchor * |
AgenciesAnywhere:crl:delete |
Grants permission to delete a certificate revocation list. |
Write |
crl * |
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 2, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for IAM Identity Broker.
Conditions
IAM Identity Broker does not support service-specific condition keys in SCPs. It can only use global condition keys applicable to all services. For details, see Global Condition Keys.
