Cloud Connect (CC)
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (such as list, read, or write). This classification helps you understand the level of access that an action grants when you use it in an SCP policy.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by Cloud Connect, see Resources.
- The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by Cloud Connect, see Conditions.
The following table lists the actions that you can define in SCP statements for Cloud Connect.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
cc:cloudConnections:create |
Grants permission to create a cloud connection. |
write |
cloudConnection * |
cc:cloudConnections:delete |
Grants permission to delete a cloud connection. |
write |
cloudConnection * |
cc:cloudConnections:update |
Grants permission to update a cloud connection. |
write |
cloudConnection * |
cc:cloudConnections:get |
Grants permission to query the details of a cloud connection. |
read |
cloudConnection * |
cc:cloudConnections:list |
Grants permission to list the cloud connections. |
list |
cloudConnection * |
cc:cloudConnections:tag |
Grants permission to add tags to a cloud connection. |
tagging |
cloudConnection * |
cc:cloudConnections:unTag |
Grants permission to delete tags from a cloud connection. |
tagging |
cloudConnection * |
cc:cloudConnections:listTags |
Grants permission to list the tags added to a cloud connection. |
list |
cloudConnection * |
cc:networkInstances:create |
Grants permission to load a network instance. |
write |
networkInstance * |
cloudConnection * |
g:ResourceTag/<tag-key> |
cc:networkInstances:delete |
Grants permission to remove a network instance. |
write |
networkInstance * |
cloudConnection * |
g:EnterpriseProjectId |
cc:networkInstances:update |
Grants permission to update a network instance. |
write |
networkInstance * |
cloudConnection * |
cc:networkInstances:get |
Grants permission to query the details of a network instance. |
read |
networkInstance * |
cloudConnection * |
cc:networkInstances:list |
Grants permission to list the network instances. |
list |
networkInstance * |
cc:bandwidthPackages:create |
Grants permission to create a bandwidth package. |
write |
bandwidthPackage * |
cc:bandwidthPackages:delete |
Grants permission to delete a bandwidth package. |
write |
cc:bandwidthPackages:update |
Grants permission to update a bandwidth package. |
write |
cc:bandwidthPackages:get |
Grants permission to query the details of a bandwidth package. |
read |
cc:bandwidthPackages:list |
Grants permission to list the bandwidth packages. |
list |
cc:bandwidthPackages:tag |
Grants permission to add tags to a bandwidth package. |
tagging |
cc:bandwidthPackages:unTag |
Grants permission to delete tags from a bandwidth package. |
tagging |
cc:bandwidthPackages:listTags |
Grants permission to list the tags added to a bandwidth package. |
list |
cc:bandwidthPackages:associate |
Grants permission to bind a bandwidth package to a cloud connection. |
write |
cloudConnection * |
cc:bandwidthPackages:disassociate |
Grants permission to unbind a bandwidth package from a cloud connection. |
write |
cloudConnection * |
cc:interRegionBandwidths:create |
Grants permission to assign an inter-region bandwidth. |
write |
interRegionBandwidth * |
cloudConnection * |
cc:interRegionBandwidths:delete |
Grants permission to delete an inter-region bandwidth. |
write |
cc:BandwidthPackageId |
cloudConnection * |
cc:interRegionBandwidths:update |
Grants permission to modify an inter-region bandwidth. |
write |
cloudConnection * |
cc:interRegionBandwidths:get |
Grants permission to query the details of an inter-region bandwidth. |
read |
cloudConnection * |
cc:interRegionBandwidths:list |
Grants permission to list the inter-region bandwidths. |
list |
cc:cloudConnectionRoutes:get |
Grants permission to query the details of a cloud connection route. |
read |
cc:cloudConnectionRoutes:list |
Grants permission to list the cloud connection routes. |
list |
cc:authorisation:create |
Grants permission to allow other accounts to load the VPCs in your account to their cloud connections. |
write |
cc:authorisation:delete |
Grants permission to stop allowing other accounts to load the VPCs in your account to their cloud connections. |
write |
cc:authorisation:update |
Grants permission to update the authorization that allows other accounts to load the VPCs in your account to their cloud connections. |
write |
cc:authorisation:list |
Grants permission to list the VPCs that are allowed to be loaded to the cloud connections in other accounts. |
list |
cc:authorisation:listPermissions |
Grants permission to list the VPCs that other accounts allow you to load to your cloud connection. |
list |
cc:centralNetwork:create |
Grants permission to create a central network. |
write |
centralNetwork * |
cc:centralNetwork:delete |
Grants permission to delete a central network. |
write |
centralNetwork * |
cc:centralNetwork:update |
Grants permission to update a central network. |
write |
centralNetwork * |
cc:centralNetwork:get |
Grants permission to query the details of a central network. |
read |
centralNetwork * |
cc:centralNetwork:list |
Grants permission to list the central networks. |
list |
centralNetwork * |
cc:centralNetwork:tag |
Grants permission to add tags to a central network. |
tagging |
centralNetwork * |
cc:centralNetwork:unTag |
Grants permission to delete tags from a central network. |
tagging |
centralNetwork * |
cc:centralNetwork:listTags |
Grants permission to list the tags added to a central network. |
list |
centralNetwork * |
cc:centralNetwork:createPolicy |
Grants permission to add a policy to a central network. |
write |
centralNetwork * |
cc:MultipleEnterpriseRouterIds |
cc:centralNetwork:applyPolicy |
Grants permission to apply a policy to a central network. |
write |
centralNetwork * |
cc:centralNetwork:deletePolicy |
Grants permission to delete a policy from a central network. |
write |
centralNetwork * |
cc:centralNetwork:listPolicies |
Grants permission to list the central network policies. |
list |
centralNetwork * |
cc:centralNetwork:listChangeSet |
Grants permission to query the changes between the current policy and the applied policy. |
list |
centralNetwork * |
cc:centralNetwork:listConnections |
Grants permission to list the central network connections. |
list |
centralNetwork * |
cc:centralNetwork:updateConnection |
Grants permission to update a central network connection. |
write |
centralNetwork * |
cc:GlobalConnectionBandwidthId |
cc:centralNetworkAttachment:createGdgw |
Grants permission to add a global DC gateway to a central network as an attachment. |
write |
centralNetworkAttachment * |
centralNetwork * |
cc:centralNetworkAttachment:updateGdgw |
Grants permission to update a global DC gateway on a central network. |
write |
centralNetwork * |
cc:centralNetworkAttachment:getGdgw |
Grants permission to query the details of a global DC gateway on a central network. |
read |
centralNetwork * |
cc:centralNetworkAttachment:listGdgws |
Grants permission to list the global DC gateways on a central network. |
list |
centralNetwork * |
cc:centralNetworkAttachment:createErRouteTable |
Grants permission to add an enterprise router route table to a central network as an attachment. |
write |
centralNetwork * |
cc:centralNetworkAttachment:updateErRouteTable |
Grants permission to update an enterprise router route table on a central network. |
write |
centralNetwork * |
cc:centralNetworkAttachment:getErRouteTable |
Grants permission to query the details of an enterprise router route table on a central network. |
read |
centralNetwork * |
cc:centralNetworkAttachment:listErRouteTables |
Grants permission to list the enterprise router route tables on a central network. |
list |
centralNetwork * |
cc:centralNetworkAttachment:delete |
Grants permission to delete an attachment from a central network. |
write |
centralNetwork * |
cc:centralNetworkAttachment:list |
Grants permission to list the central network attachments. |
list |
centralNetwork * |
Each API of Cloud Connect usually supports one or more actions. Table 2 lists the supported actions and dependencies.
API |
Action |
Dependencies |
POST /v3/{domain_id}/ccaas/cloud-connections |
PUT /v3/{domain_id}/ccaas/cloud-connections/{id} |
DELETE /v3/{domain_id}/ccaas/cloud-connections/{id} |
GET /v3/{domain_id}/ccaas/cloud-connections/{id} |
GET /v3/{domain_id}/ccaas/cloud-connections |
POST /v3/{domain_id}/ccaas/cloud-connections/filter |
POST /v3/{domain_id}/ccaas/cloud-connections/{id}/tag |
POST /v3/{domain_id}/ccaas/cloud-connections/{id}/untag |
GET /v3/{domain_id}/ccaas/cloud-connections/tags |
POST /v3/{domain_id}/ccaas/network-instances |
PUT /v3/{domain_id}/ccaas/network-instances/{id} |
DELETE /v3/{domain_id}/ccaas/network-instances/{id} |
GET /v3/{domain_id}/ccaas/network-instances/{id} |
GET /v3/{domain_id}/ccaas/network-instances |
POST /v3/{domain_id}/ccaas/bandwidth-packages |
PUT /v3/{domain_id}/ccaas/bandwidth-packages/{id} |
DELETE /v3/{domain_id}/ccaas/bandwidth-packages/{id} |
GET /v3/{domain_id}/ccaas/bandwidth-packages/{id} |
GET /v3/{domain_id}/ccaas/bandwidth-packages |
POST /v3/{domain_id}/ccaas/bandwidth-packages/filter |
POST /v3/{domain_id}/ccaas/bandwidth-packages/{id}/tag |
POST /v3/{domain_id}/ccaas/bandwidth-packages/{id}/untag |
GET /v3/{domain_id}/ccaas/bandwidth-packages/tags |
POST /v3/{domain_id}/ccaas/bandwidth-packages/{id}/associate |
POST /v3/{domain_id}/ccaas/bandwidth-packages/{id}/disassociate |
POST /v3/{domain_id}/ccaas/inter-region-bandwidths |
PUT /v3/{domain_id}/ccaas/inter-region-bandwidths/{id} |
DELETE /v3/{domain_id}/ccaas/inter-region-bandwidths/{id} |
GET /v3/{domain_id}/ccaas/inter-region-bandwidths/{id} |
GET /v3/{domain_id}/ccaas/inter-region-bandwidths |
GET /v3/{domain_id}/ccaas/cloud-connection-routes/{id} |
GET /v3/{domain_id}/ccaas/cloud-connection-routes |
POST /v3/{domain_id}/ccaas/authorisations |
DELETE /v3/{domain_id}/ccaas/authorisations/{id} |
PUT /v3/{domain_id}/ccaas/authorisations/{id} |
GET /v3/{domain_id}/ccaas/authorisations |
GET /v3/{domain_id}/ccaas/permissions |
GET /v3/{domain_id}/ccaas/quotas |
cc:quota:list |
GET /v3/{domain_id}/gcn/quotas |
cc:quota:list |
GET /v3/{domain_id}/ccaas/capabilities |
cc:capability:list |
GET /v3/{domain_id}/gcn/capabilities |
POST /v3/{domain_id}/gcn/central-networks |
DELETE /v3/{domain_id}/gcn/central-networks/{central_network_id} |
PUT /v3/{domain_id}/gcn/central-networks/{central_network_id} |
GET /v3/{domain_id}/gcn/central-networks/{central_network_id} |
GET /v3/{domain_id}/gcn/central-networks |
POST /v3/{domain_id}/gcn/central-networks/filter |
POST /v3/{domain_id}/gcn/central-networks/{central_network_id}/tag |
POST /v3/{domain_id}/gcn/central-networks/{central_network_id}/untag |
GET /v3/{domain_id}/gcn/central-networks/tags |
POST /v3/{domain_id}/gcn/central-network/{central_network_id}/policies |
POST /v3/{domain_id}/gcn/central-network/{central_network_id}/policies/{policy_id}/apply |
DELETE /v3/{domain_id}/gcn/central-network/{central_network_id}/policies/{policy_id} |
GET /v3/{domain_id}/gcn/central-network/{central_network_id}/policies |
GET /v3/{domain_id}/gcn/central-network/{central_network_id}/policies/{policy_id}/change-set |
GET /v3/{domain_id}/gcn/central-network/{central_network_id}/connections |
PUT /v3/{domain_id}/gcn/central-network/{central_network_id}/connections/{connection_id} |
POST /v3/{domain_id}/gcn/central-network/{central_network_id}/gdgw-attachments |
PUT /v3/{domain_id}/gcn/central-network/{central_network_id}/gdgw-attachments/{gdgw_attachment_id} |
GET /v3/{domain_id}/gcn/central-network/{central_network_id}/gdgw-attachments/{gdgw_attachment_id} |
GET /v3/{domain_id}/gcn/central-network/{central_network_id}/gdgw-attachments |
POST /v3/{domain_id}/gcn/central-network/{central_network_id}/er-route-table-attachments |
PUT /v3/{domain_id}/gcn/central-network/{central_network_id}/er-route-table-attachments/{er_route_table_attachment_id} |
GET /v3/{domain_id}/gcn/central-network/{central_network_id}/er-route-table-attachments/{er_route_table_attachment_id} |
GET /v3/{domain_id}/gcn/central-network/{central_network_id}/er-route-table-attachments |
DELETE /v3/{domain_id}/gcn/central-network/{central_network_id}/attachments/{attachment_id} |
GET /v3/{domain_id}/gcn/central-network/{central_network_id}/attachments |
Resources
A resource type indicates the resources that an SCP policy applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP policy to define resource types.
The following table lists the resource types that you can define in SCP statements for Cloud Connect.
Resource Type |
URN |
cloudConnection |
cc::<account-id>:cloudConnection:<cloud-connection-id> |
interRegionBandwidth |
cc::<account-id>:interRegionBandwidth:<inter-region-bandwidth-id> |
networkInstance |
cc::<account-id>:networkInstance:<network-instance-id> |
siteNetwork |
cc::<account-id>:siteNetwork:<site-network-id> |
bandwidthPackage |
cc::<account-id>:bandwidthPackage:<bandwidth-package-id> |
centralNetwork |
cc::<account-id>:centralNetwork:<central-network-id> |
centralNetworkAttachment |
cc::<account-id>:centralNetworkAttachment:<central-network-attachment-id> |
Conditions
A Condition element lets you specify conditions for when an SCP is in effect. It contains condition keys and operators.
- A key in the Condition element of a statement can be a global condition key or a service-specific condition key.
- Global condition keys (with the g: prefix) apply to all actions. Cloud services do not need to provide user identity information. Instead, the system automatically obtains such information and authenticates users. For details, see Global Condition Keys.
- Service-specific condition keys (with the abbreviation of a service name plus a colon as the prefix, for example, cc:) apply only to operations of Cloud Connect. For details, see Table 4.
- The number of values associated with a condition key in the request context of an API call makes the condition key single-valued or multivalued. Single-valued condition keys have at most one value in the request context of an API call. Multivalued condition keys can have multiple values in the request context of an API call. For example, a request can originate from at most one VPC endpoint, so g:SourceVpce is a single-valued condition key. You can tag resources and include multiple tag key-value pairs in a request, so g:TagKeys is a multivalued condition key.
- A condition operator, condition key, and a condition value together constitute a complete condition statement. An SCP can be applied only when its request conditions are met. For details about the supported operators, see operators.
The following table lists the condition keys that you can define in SCPs for Cloud Connect. You can include these condition keys to specify conditions for when your SCP is in effect.
Service-specific Condition Key |
Type |
Single-valued/Multivalued |
What To Do |
cc:VpcId |
string |
Single-valued |
VPC ID as a filter. |
cc:VirtualGatewayId |
string |
Single-valued |
Direct Connect virtual gateway ID as a filter. |
cc:EnterpriseRouterId |
string |
Single-valued |
Enterprise router ID as a filter. |
string |
Multivalued |
Enterprise router IDs as a filter. |
string |
Single-valued |
Bandwidth package ID as a filter. |
string |
Single-valued |
Global private bandwidth ID as a filter. |
cc:GlobalDcGatewayId |
string |
Single-valued |
Global DC gateway ID as a filter. |
