MapReduce Service (MRS)
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to an entity. They only set the permissions boundary for the entity. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
- The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
- The Resource Type column indicates whether the action supports resource-level permissions.
- You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions and you must specify all resources ("*") in your SCP statements.
- If this column includes a resource type, you must specify the URN in the Resource element of your statements.
- Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
For details about the resource types defined by MRS, see Resources.
- The Condition Key column includes keys that you can specify in the Condition element of an SCP statement.
- If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
- If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
- If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
For details about the condition keys defined by MRS, see Conditions.
The following table lists the actions that you can define in SCPs for MRS.
Action |
Description |
Access Level |
Resource Type (*: required) |
Condition Key |
mrs:cluster:createCluster |
Grants permission to create a cluster. |
write |
mrs:<region>:<account-id>:cluster:<cluster-id> |
mrs:cluster:deleteCluster |
Grants permission to delete a cluster. |
write |
mrs:cluster:listHosts |
Grants permission to query nodes in a cluster. |
list |
mrs:cluster:listFiles |
Grants permission to query files in a cluster. |
list |
mrs:cluster:createJob |
Grants permission to execute jobs in a cluster. |
write |
mrs:cluster:list |
Grants permission to query the cluster list. |
list |
mrs:cluster:listJobs |
Grants permission to query jobs of a cluster. |
list |
mrs:cluster:getJob |
Grants permission to query job details in a cluster. |
read |
mrs:cluster:getCluster |
Grants permission to query cluster details. |
read |
mrs:cluster:resizeNodes |
Grants permission to adjust cluster nodes. |
write |
mrs:cluster:updateClusterName |
Grants permission to rename a cluster. |
write |
mrs:cluster:listTags |
Grants permission to query cluster tags. |
list |
mrs:cluster:updateTags |
Grants permission to add or delete cluster tags. |
tagging |
mrs:cluster:listClustersByTag |
Grants permission to query clusters with specific tags. |
list |
mrs:cluster:stopJob |
Grants permission to stop cluster jobs. |
write |
mrs:cluster:deleteJobs |
Grants permission to delete cluster jobs in batches. |
write |
mrs:cluster:stopSql |
Grants permission to cancel SQL execution. |
write |
mrs:cluster:createSql |
Grants permission to submit SQL statements for execution. |
write |
mrs:cluster:listPolicies |
Grants permission to obtain all auto scaling policies in a cluster. |
list |
mrs:cluster:updatePolicies |
Grants permission to modify the auto scaling policies of a cluster. |
write |
mrs:cluster:getAgencyMapping |
Grants permission to obtain user agent information. |
read |
mrs:cluster:updateAgencyMapping |
Grants permission to update user agent information. |
write |
mrs:cluster:getSql |
Grants permission to obtain the SQL execution result. |
read |
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 2, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for MRS.
Conditions
MRS does not support service-specific condition keys in SCPs.
It can only use global condition keys applicable to all services. For details, see Global Condition Keys.
